22" FHD monitor Stylish new design SE390 S22E390H
- Define your space with a stylish new design accentuated by slim bezels and soft blue light
Brilliant picture quality for the optimal viewing experience
New Slim ToC: With a beautiful new semi-transparent blue finish, Samsung’s innovative Touch of Color technology optimizes your living space and completely sets it apart.
- T-Shaped Stand: Using Touch of Color for the T-shape stand completes the ensemble with a refined, minimal finish.
- Samsung S22E390H - SE390 Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- High-gloss black
- 51.906 cm x 16.746 cm x 39.168 cm
- 3.55 kg
- Environmental Standards
- ENERGY STAR Qualified
- IEC 62087 Edition 2
- Display Type
- Energy Class
- Class B
- 31 kWh
- Diagonal Size
- 21.5"
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
- High-gloss black
- 51.906 cm x 16.746 cm x 39.168 cm - with stand
- 3.55 kg
- VGA , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- PVC free
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 51.906 cm - depth: 16.746 cm - height: 39.168 cm - weight: 3.55 kg , Without stand - width: 51.906 cm - depth: 7.008 cm - height: 32.77 cm - weight: 3.05 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
