Featuring a dedicated game mode, the LS19F355 LED Monitor is able to optimise colour and contrast for gaming, so you can enjoy every scene in great quality. Comfortable viewing To reduce fatigue after long gaming sessions, the LS19F355 Monitor has Eye Saver Mode, which reduces blue light emissions for a more comfortable viewing experience. Slim design The Samsung LS19F355 18.5" LED Monitor is incredibly slim at only 10 mm, which is as thin as a ballpoint pen. It looks great on your desk and can also be mounted on the wall - all you need is a standard TV bracke
- Samsung S19F355HNU - SF355 Series - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V
- High glossy black
- 44.2 cm x 17.4 cm x 35.54 cm
- 2 kg
- Display Type
- Diagonal Size
- 19"
- Viewable Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
- High glossy black
- 44.2 cm x 17.4 cm x 35.54 cm - with stand
- 2 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -2/+22
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 15 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 44.2 cm - depth: 17.4 cm - height: 35.54 cm - weight: 2 kg , Without stand - width: 44.2 cm - depth: 6.81 cm - height: 26.46 cm - weight: 1.7 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
