Samsung S19F355H 19" 1366x768 5ms VGA LED Monitor
Quicklinx: D7CZWS00 Mfr#: LS19F355HNUXEN
Select:
  • 18.5"
Featuring a dedicated game mode, the LS19F355 LED Monitor is able to optimise colour and contrast for gaming, so you can enjoy every scene in great quality. Comfortable viewing To reduce fatigue after long gaming sessions, the LS19F355 Monitor has Eye Saver Mode, which reduces blue light emissions for a more comfortable viewing experience. Slim design The Samsung LS19F355 18.5" LED Monitor is incredibly slim at only 10 mm, which is as thin as a ballpoint pen. It looks great on your desk and can also be mounted on the wall - all you need is a standard TV bracke
Samsung S19F355HNU - SF355 Series - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
High glossy black
44.2 cm x 17.4 cm x 35.54 cm
2 kg
Display Type
Diagonal Size
19"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
High glossy black
44.2 cm x 17.4 cm x 35.54 cm - with stand
2 kg
VGA
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
15 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 44.2 cm - depth: 17.4 cm - height: 35.54 cm - weight: 2 kg , Without stand - width: 44.2 cm - depth: 6.81 cm - height: 26.46 cm - weight: 1.7 kg
20 - 80% (non-condensing)
