Samsung S19E200BW 18.9" 1440x900 5ms VGA DVI LED Monitor
Quicklinx: BK41WS00 Mfr#: LS19E20KBW/EN
Clear picture quality with fast response time
  • Fast 5 ms Response Time: See even fast on-screen motion clearly and smoothly with less motion blur, judder or ghosting.
  • Full HD Resolution: Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all of your content clearly
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy with energy-efficient features
  • SMART Eco Saving: The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen’s black sections while simultaneously adjusting the RGB gain values.
  • Off Timer Plus: The SE200 offers an Off Timer setting that automatically turns off your monitor after a pre-set time, and an Eco Timer setting that turns off your monitor after a pre-set period of inactivity, reducing energy consumption.
Eco-friendly materials with Intertek Green Leaf certification
  • Recycled Plastics: All Samsung business monitors are made of 30% recycled plastics. -
  • PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact.
  • Accessory Packaging: Samsung has reduced the LDPE** in accessory packaging from 100% to 80% by using bio-friendly Sugar cane (20%) as an alternative manufacturing material. Samsung packaging is now Vinçotte-certified.
  • Some cabling contains PVC. ** LDPE (Low-Density Polyethylene): A thermoplastic made from the monomer ethylene.
  • Fast 5 ms response time
    See even fast on-screen motion clearly and smoothly with less motion blur, judder, or ghosting.
  • Full HD resolution
    Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all your content clearly.
  • Eye saver mode
    Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free technology
  • Smart eco saving
    The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen's black sections while simultaneously adjusting the RGB gain values.
  • Off timer plus
    The SE200 offers an off timer setting that automatically turns off your monitor after a pre-set time, and an eco-timer setting that turns off your monitor after a pre-set period of inactivity, reducing energy consumption.
Samsung S19E200BW - SE200 Series - LED monitor - 18.9"
LED-backlit LCD monitor - 18.9"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
43.94 cm x 17 cm x 37.36 cm
3.01 kg
Environmental Standards
ENERGY STAR Qualified
EN55022, EN55024, FCC Part 15 B, AS/NZS 3548, EN 60950-1, cULus, GB 9254-2008, K60950-1, KCC KN22, KCC KN24, UL60950-1, GB 4943-2011, GB 17625.1-2012, IEC60950-1
3-year warranty
Display Type
Diagonal Size
18.9"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, power off timer, MagicAngle, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, 72% NTSC colour gamut
43.94 cm x 17 cm x 37.36 cm - with stand
3.01 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-1/+20
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.1 Watt
Power Consumption Sleep
0.1 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 43.94 cm - depth: 17 cm - height: 37.36 cm - weight: 3.01 kg , Without stand - width: 43.94 cm - depth: 7.69 cm - height: 28.99 cm - weight: 2.72 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
10 °C
10 - 80% (non-condensing)
