Clear picture quality with fast response time
- Fast 5 ms Response Time: See even fast on-screen motion clearly and smoothly with less motion blur, judder or ghosting.
- Full HD Resolution: Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all of your content clearly
Easy on the eyes for a more comfortable viewing experience
- Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
- Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy with energy-efficient features
- SMART Eco Saving: The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen’s black sections while simultaneously adjusting the RGB gain values.
- Off Timer Plus: The SE200 offers an Off Timer setting that automatically turns off your monitor after a pre-set time, and an Eco Timer setting that turns off your monitor after a pre-set period of inactivity, reducing energy consumption.
Eco-friendly materials with Intertek Green Leaf certification
- Recycled Plastics: All Samsung business monitors are made of 30% recycled plastics. -
- PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact.
Accessory Packaging: Samsung has reduced the LDPE** in accessory packaging from 100% to 80% by using bio-friendly Sugar cane (20%) as an alternative manufacturing material. Samsung packaging is now Vinçotte-certified.
Some cabling contains PVC. ** LDPE (Low-Density Polyethylene): A thermoplastic made from the monomer ethylene.
Fast 5 ms response time
See even fast on-screen motion clearly and smoothly with less motion blur, judder, or ghosting. -
Full HD resolution
Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all your content clearly. -
Eye saver mode
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. -
Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Smart eco saving
The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen's black sections while simultaneously adjusting the RGB gain values. -
Off timer plus
The SE200 offers an off timer setting that automatically turns off your monitor after a pre-set time, and an eco-timer setting that turns off your monitor after a pre-set period of inactivity, reducing energy consumption.
- Samsung S19E200BW - SE200 Series - LED monitor - 18.9"
- LED-backlit LCD monitor - 18.9"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900 at 60 Hz
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 43.94 cm x 17 cm x 37.36 cm
- 3.01 kg
- Environmental Standards
- ENERGY STAR Qualified
- EN55022, EN55024, FCC Part 15 B, AS/NZS 3548, EN 60950-1, cULus, GB 9254-2008, K60950-1, KCC KN22, KCC KN24, UL60950-1, GB 4943-2011, GB 17625.1-2012, IEC60950-1
- 3-year warranty
- Display Type
- Diagonal Size
- 18.9"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, power off timer, MagicAngle, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, 72% NTSC colour gamut
- Black
- 43.94 cm x 17 cm x 37.36 cm - with stand
- 3.01 kg
- VGA , DVI
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 100 x 100 mm
- PVC free
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.1 Watt
- Power Consumption Sleep
- 0.1 Watt
- OS Required
- Windows 8.1
- Dimensions & Weight Details
- With stand - width: 43.94 cm - depth: 17 cm - height: 37.36 cm - weight: 3.01 kg , Without stand - width: 43.94 cm - depth: 7.69 cm - height: 28.99 cm - weight: 2.72 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
