SSG-3570CR can be used for up to 40 hours with a quick charge of 30 minutes. Its ergonomic design makes for a comfortable wearing experience, with the nose supporting only half of the weight of the glasses. The glasses also support auto power on/off, which automatically turns off the glasses after the idling time is reached, an eco-friendly design that saves battery.
- Samsung SSG-3570CR - 3D glasses
- Product Type
- 3D glasses - active shutter
- Battery
- Rechargeable
- Run Time (Up To)
- 40 hours
- Package Content
- 3D glasses, USB charge cable
- 14.2 cm x 17 cm x 4 cm
- 29 g
- Designed For
- Samsung PN51F8500, PN60F8500, PN64F8500, PS51F5500, PS60F5500, UE32F6100, UE32F6400, UE32F6800, UE40F6100, UE40F6800, UE40F7000, UE46F6100, UE46F6500, UE46F6800, UE50F6400, UE50F6500, UE55F6500, UE55F6800, UE65F6400, UE65F8000, UE75F6400, UN40FH6030, UN46F6800, UN46FH6030, UN55F7500, UN55FH6030
- Product Type
- 3D glasses
- 3D Glasses Technology
- Active shutter
- Package Content
- 14.2 cm
- 17 cm
- 4 cm
- 29 g
- Rechargeable Battery
- Rechargeable
- Run Time (Up To)
- 40 hours
- Designed For
- Samsung PN43D490, PN51D490, PN51D550, PN51D6500, PN51D7000, PN51D8000, PN51E550, PN51E6500, PN51E8000, PN51F5500, PN51F8500, PN59D550, PN59D6500, PN59D7000, PN59D8000, PN60F5500, PN60F8500, PN64D550, PN64D7000, PN64D8000, PN64F5500, PN64F8500, PS43F4900, PS51F4900, PS51F5500, PS60F5500, UE32F6100, UE32F6400, UE32F6510, UE32F6800, UE40F6100, UE40F6400, UE40F6500, UE40F6510, UE40F6800, UE40F7000, UE40F8000, UE46F6100, UE46F6400, UE46F6500SD, UE46F6510, UE46F6800, UE46F7000, UE46F8000, UE50F6400, UE50F6500SD, UE55F6100, UE55F6400, UE55F6500SD, UE55F6510, UE55F6800, UE55F7000, UE55F8000, UE55F8500, UE60F6100, UE65F6400, UE65F8000, UE75F6400, UE75F8000, UN40D6400, UN40D6420, UN40D6500, UN40ES6500, UN40F6400, UN40FH6030, UN46D6400, UN46D6420, UN46D6900, UN46D7000, UN46D7900, UN46D8000, UN46ES6500, UN46F6400, UN46F6800, UN46F7100, UN46F7500, UN46F8000, UN46FH6030, UN50ES6500, UN50F6400, UN55D6400, UN55D6420, UN55D6900, UN55D7000, UN55D7900, UN55D8000, UN55F6400, UN55F7100, UN55F7500, UN55F8000, UN55FH6030, UN60D6400, UN60D6500, UN60D7000, UN60D8000, UN60ES7500, UN60F6400, UN60F7100, UN60F7500, UN60F8000, UN65D8000, UN65ES8000, UN65F6400, UN65F7100, UN65F8000, UN75F6400, UN75F7100, UN75F8000
