With stunning 4K quality 85" UHD QM-D Series display provides high pixel density, fine detail and exceptional stopping power. You can even display Full HD content in 4K via UHD upscaling. Whether it's in your retail space, corporate boardroom or public area, you can make every impression count.
Stunning UHD (4K) picture
3840 x 2160 resolution delivers life-like image quality. Experience a high-impact way to communicate in retail spaces, hospitality, corporate boardrooms, healthcare environments and more. -
Impactful 85" screen
The QM85D features a big, beautiful 85" UHD panel, for engaging images and messages that cannot be ignored. Imagine the possibilities. -
Upscaling technology
Even if you don't have the best quality content, the QM85D upconverts low-resolution content to create the sharpest images possible. You can even display Full HD content in 4K via UHD upscaling. -
Multi-screen delivers multiple messages
The Picture by Picture function allows you to display up to 4 content feeds at once, each supporting Full HD 1080p resolution. It's ideal for retail, videoconferencing and command control applications. -
60 Hz (FPS) Playback
High-definition DisplayPort ports mean you can faithfully display full 60 Hz (FPS) content playback.
- Samsung QM85D QMD Series - 85" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 85"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Auto Source Switching & Recovery
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 495 Watt
- Power Consumption (On mode)
- 375 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 548 kWh
- Dimensions (WxDxH) - without stand
- 190.34 cm x 10.51 cm x 109.05 cm
- 55.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 495 Watt
- 375 W
- 548 kWh
- Diagonal Class
- 85"
- Commercial Use
- Series
- QMD Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 190.34 cm
- 10.51 cm
- 109.05 cm
- 55.5 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 5000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1625 x 0.1625mm
- Response Time
- 6 ms
- Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Optional Touch Overlay, Certified for 16/7 Continuous Operation
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 30 Watt
- Speakers
- 2 x main channel speaker - 15 Watt
- Connector Type
- 3 x HDMI input , DVI-D input , VGA input , Audio line-out , Serial input , Serial output , Audio line-in , Multiple Display Control , Remote control/ambient sensor input , Remote control output , USB 2.0 , 3 x DisplayPort input
- Cables Included
- DisplayPort cable
- Plug and Play, DDC/CI, EMC Class A
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 205 cm
- Depth (Shipping)
- 47.2 cm
- Height (Shipping)
- 126.5 cm
- Weight (Shipping)
- 71.4 kg
- 0 °C
- 40 °C
- 10 - 80%
