Samsung QM85D 85" 3840x2160 VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: B4TYWS00 Mfr#: LH85QMDPLGC/EN
Video Interface: HDMI
TV Tuner Presence: No
£7,424.15 ex VAT
£8,908.98 inc VAT
With stunning 4K quality 85" UHD QM-D Series display provides high pixel density, fine detail and exceptional stopping power. You can even display Full HD content in 4K via UHD upscaling. Whether it's in your retail space, corporate boardroom or public area, you can make every impression count.
  • Stunning UHD (4K) picture
    3840 x 2160 resolution delivers life-like image quality. Experience a high-impact way to communicate in retail spaces, hospitality, corporate boardrooms, healthcare environments and more.
  • Impactful 85" screen
    The QM85D features a big, beautiful 85" UHD panel, for engaging images and messages that cannot be ignored. Imagine the possibilities.
  • Upscaling technology
    Even if you don't have the best quality content, the QM85D upconverts low-resolution content to create the sharpest images possible. You can even display Full HD content in 4K via UHD upscaling.
  • Multi-screen delivers multiple messages
    The Picture by Picture function allows you to display up to 4 content feeds at once, each supporting Full HD 1080p resolution. It's ideal for retail, videoconferencing and command control applications.
  • 60 Hz (FPS) Playback
    High-definition DisplayPort ports mean you can faithfully display full 60 Hz (FPS) content playback.
Samsung QM85D QMD Series - 85" LED-backlit LCD display - 4K
LED-backlit LCD flat panel display
Diagonal Class
85"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery
Speaker System
2 speakers
USB
Remote control
Voltage
Energy Class
Class B
495 Watt
Power Consumption (On mode)
375 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
548 kWh
190.34 cm x 10.51 cm x 109.05 cm
55.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
495 Watt
375 W
548 kWh
Diagonal Class
85"
Commercial Use
Series
QMD Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
190.34 cm
10.51 cm
109.05 cm
55.5 kg
Display
225
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1625 x 0.1625mm
Response Time
6 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Optional Touch Overlay, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - 15 Watt
Connector Type
3 x HDMI input , DVI-D input , VGA input , Audio line-out , Serial input , Serial output , Audio line-in , Multiple Display Control , Remote control/ambient sensor input , Remote control output , USB 2.0 , 3 x DisplayPort input
DisplayPort cable
Plug and Play, DDC/CI, EMC Class A
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
205 cm
Depth (Shipping)
47.2 cm
Height (Shipping)
126.5 cm
Weight (Shipping)
71.4 kg
10 - 80%
Brand: Samsung
Price Range Ex VAT: £1500+
