Product
Samsung QM49H 49 UHD 24/7 500NIT SSSP V5
Quicklinx: DD0KWS00 Mfr#: LH49QMHPLGC/EN
TV Tuner Presence: No
Video Interface: HDMI
38 in stock
£1,134.73 ex VAT
£1,361.67 inc VAT
Samsung's QMH series displays deliver content with visual impact while also improving operational efficiency. Through UHD picture quality, the displays foster an inviting and memorable viewing environment. Additionally, these displays undergo thorough testing and certification to ensure round-the-clock performance. Backed by the powerful SSSP 5.0 and TIZEN 3.0 operating system, the displays feature a host of business-ready functionalities while also protecting business data through enhanced security.
Featuring state-of-the-art UHD picture quality, the QMH series displays empower users to deliver more impactful messaging. Each QMH series display showcases content with four times the ultra-realistic detail and clarity of standard alternatives, with a wider screen offering more space for imagery. When combined with performance features, such as portrait mode, this next-level presentation makes the QMH series ideal for any commercial setting.
For government, financial and other information-based businesses, data protection is paramount for efficient operations. Samsung's QMH series displays accommodate this need through intense security measures. The embedded TIZEN 3.0 OS offers defense across the application, platform and system layers, restricting file and data access to an exclusive user base.
  • Deliver impactful content through an all-inclusive display
  • Enliven commercial content with UHD picture quality
  • Protect business and customer data through extensive security
  • Ensure continuous performance in any condition
    A durable design enables the QMH series displays to deliver content around the clock without interruption, regardless of the surrounding conditions. Prior to distribution, the QMH series displays undergo rigorous IP5x certification to deter any potential impact from dust exposure. In turn, transportation hubs and other settings that face a host of natural and man-made variables can implement the displays without an external enclosure.
  • Achieve brilliant, glare-free picture quality
    Samsung's QMH series displays ensure readability in any environment through a rigid non-glare front panel. This enhanced design reduces reflection and maintains clear visibility for featured text and imagery. As a result, indoor and outdoor businesses who face frequent exposure to bright natural or ambient lighting can deploy compelling content without having to worry about interference.
Samsung QM49H QMH Series - 49" LED display
LED-backlit LCD flat panel display
Diagonal Class
49"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, Bluetooth
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Mega Dynamic Contrast Ratio
USB
2 ports
Voltage
Energy Class
Class B
154 Watt
Power Consumption (On mode)
101 W
Energy Consumption per Year
147 kWh
Energy Class
Class B
154 Watt
101 W
147 kWh
Diagonal Class
49"
Commercial Use
Series
QMH Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
4700:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
MagicInfo, Daisy Chain
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Connector Type
DVI-Digital , DisplayPort input , 2 x HDMI input , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , LAN , Infrared input
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, EN 60950-1, FCC Part 15 B Class A, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, IS13252, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, BIS, INMETRO, IEC60950-1, EN 55024:1998+A1:2001+A2:2003, KCC/EK
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
119.5 cm
Depth (Shipping)
17.7 cm
Height (Shipping)
72.1 cm
Weight (Shipping)
17.5 kg
10 - 80%
Brand: Samsung
Price Range Ex VAT: 1000 - 1500
