Samsung's QMR series displays cut through the clutter to deliver advanced UHD resolution as well as intelligent UHD upscaling and rich flawless colors with Dynamic Crystal Color all in a slim design.
Incredible 4K picture quality
Samsung's QMR series provides ultra-high-definition 4K resolution, creating lifelike images with sharper picture quality than ever before. -
Intelligent UHD upscaling
Samsung's intelligent UHD upscaling technology performs edge restoration and noise reduction to deliver perfect UHD picture quality even with lower resolution content. This "future-proof" solution ensures high picture quality regardless of the original content resolution. -
The QMR series features Dynamic Crystal Color, using 10 bit processing for flawless color expression, allowing viewers to enjoy a wider spectrum of colors up to one billion shades. HDR+ functionality converts standard definition content to HDR quality for sharper contrast and more vivid colors. -
Perfect view with non-glare display
The QMR series features reliable, non-glare panels that provide better visibility from all angles, anytime of day allowing businesses to deliver accurate information 24/7 in locations where clear and accurate information is crucial such as airports and commuter stations. -
Slim and symmetrical design
The QMR series features an innovative symmetric design simplifying wall mounting and ensuring installation is seamless. The flat back and slim depth will ensure a display that will stand the test of time. -
Clean cable management
With QMR's cable guide feature, retailers are able to tuck away messy cables from view. This allows for a clean and visually-appealing shopping experience for customers, even when the back of the display is visible. -
Powerful, all-in-one solution
SSSP is an all-in-one solution that simplifies installation and maintenance. With Tizen 4.0, businesses can enjoy easy development, reinforced capability with multiple web formats and standards and secured protection. -
Wi-Fi and Bluetooth built-in
Built-in Wi-Fi and Bluetooth allow for more personalized and interactive services as well as simplifying how businesses showcase content. Whether it's to make networking simpler or enabling interactive beacon technology in-store, QMR series displays help businesses move into the future of retail.
- Samsung QM43R QMR Series - 43" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 43"
- Commercial Use
- Yes - digital signage
- Black
- Platform
- Tizen OS 4.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Technology
- HDR 10+
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- DVI, DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Picture Enhancements
- Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Crystal Color
- USB
- 2 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 110 Watt
- Power Consumption (On mode)
- 74 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 108 kWh
- Dimensions (WxDxH) - without stand
- 96.75 cm x 4.83 cm x 55.77 cm
- 10 kg
- Product Type
- Energy Class
- Class B
- 110 Watt
- 74 W
- 108 kWh
- Diagonal Class
- 43"
- Commercial Use
- Series
- QMR Series
- Platform
- Tizen OS 4.0
- HDR Capable
- HDR Technology
- HDR 10+
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Design
- Narrow Bezel Design, Slim Design, New Edge Design
- Dimensions
- Without stand
- 96.75 cm
- 4.83 cm
- 55.77 cm
- 10 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- Anti-glare, 0.44% Glass Haze
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Operation Hours / Days
- 24 / 7
- MagicInfo, Daisy Chain
Stands & Mounts
- Stand
- Optional
- VESA Mounting Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Network & Internet Multimedia
- Connectivity
- Connector Type
- 2 x HDMI input , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , RS-232 input , RS-232 output , Network , Infrared input
- CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, NEMKO, NOM, SASO, CB, FCC Part 15 B, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, EN 60950-1, KC, AS/NZS, NOM-019-SCFI-1998, K60950-1, cUL No.60950-1, EAC, NOM-001-SCFI-1993 IRAM, GB4943.1-2011, RCM, IS13252, GB 17625.1-2012, BIS, INMETRO, IEC60950-1, KN32, KN35, KCC/EK, CNS 14336-1, CISPR 32:2015, RoHS CNS 15663, CISPR 32:2016, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
- Power Device
- Power supply
- Nominal Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 109.5 cm
- Depth (Shipping)
- 15.1 cm
- Height (Shipping)
- 67.6 cm
- Weight (Shipping)
- 13.3 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
