Samsung QM32R-B 32" 1920x1080 8ms HDMI USB Large Format Display
Quicklinx: GY4PWS00 Mfr#: LH32QMRBBGCXEN
Slim, symmetrical design that will stand the test of time and ensure the QMR-B series blends seamlessly into any environment, with simple installation to get your display up and running as soon as possible.
Samsung QM32R-B QMR-B Series - 32" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Platform
Tizen OS
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DisplayPort
VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Picture Enhancements
Mega Dynamic Contrast Ratio, 72% Colour Gamut
Storage Capacity
8 GB
USB
2 ports
Voltage
AC 100-240 V (50/60 Hz)
72 Watt
72.51 cm x 3.46 cm x 41.96 cm
5.7 kg
3-year warranty
72 Watt
Diagonal Class
32"
Commercial Use
Series
QMR-B Series
Platform
Tizen OS
Operating System
Tizen OS 4.0
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Infrared (IR)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
Design
Slim Design
Dimensions
Without stand
72.51 cm
3.46 cm
41.96 cm
5.7 kg
Display
LCD Display Technology
VA
Pixel Pitch
0.36375 mm
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
2% haze
Image Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Pivot, SSSP, clean cable management, Samsung Workspace secured by Knox
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Configuration
8 GB
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
2 x HDMI input , DisplayPort input , 2 x USB 2.0 , Audio line-in , Audio line-out , RS-232 input , RS-232 output , LAN
EMC Class B, HDCP 2.2, Safety 60950-1, Safety 62368-1
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
81.2 cm
Depth (Shipping)
12 cm
Height (Shipping)
51.3 cm
Weight (Shipping)
8 kg
10 - 80%
