With the ultra-high-definition (UHD) technology, businesses can convey more impactful messaging and information with ultra-crisp detail. Samsung 105" QMD Series offers the ultimate picture quality on an immersive super-large format, 21:9 screen. This premium display's commercial-grade glossy 5K UHD Glare panels ensure reliable operation, 16/7. Impactful QM105D SMART Signage is perfectly suited for businesses that rely on detailed content or want to enhance their brand with vibrant images.
UHD Resolution (5,120 X 2,160)
The resolution on a 105" QMD Series SMART Signage is four times higher than that of an FHD screen of the same size, ensuring lifelike images and super-crisp text. Additionally, with Samsung's state-of-the-art UHD dimming function and UHD upscaling technology, you can enhance your existing FHD content to display it on you UHD screens. -
DisplayPort (DP) 1.2 support
DisplayPort (DP) 1.2 connectivity enables QMD displays to stream UHD video at a refresh rate of 60 Hz. This higher refresh rate ensures seamless video playback without choppiness, which is often observed on conventional displays with a lower 30 Hz refresh rate. -
21:9 screen ratio
QM105D displays boast an expansive screen that allows for added flexibility when displaying content of various ratios. QM105D's unique 21:9 screen delivers a more immersive experience than traditional 16:9 screens, bringing a "Wow-effect" to any space, whether in an office or luxury retail shop, enhancing both the brand image and the environment. -
Multi-screen support
With 5K resolution, QM105D SMART Signage allows you to display more information on fewer units. You can show content from a maximum of four separate input devices on the same screen without having to merge the content on a separate PC first, simplifying content management and eliminating the need for special third-party components. -
Multi input sources
Displays come equipped with three DPs (two 1.2 DPs and one 1.1 DP), three High-Definition Multimedia Interface (HDMI) ports, DVI ports and one D-sub port for added flexibility. -
Pivot function
Rotate the screen up to 90 degrees, allowing the display to be installed horizontally or vertically for greater flexibility and versatility.
- Samsung QM105D QMD Series - 105" LED-backlit LCD display - 5K - for digital signage / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 105"
- Commercial Use
- Yes - digital signage / hospitality
- Resolution
- 5120 x 2160
- Display Format
- 5K UHD (2160p)
- Frame Rate & Enhancement Technology
- 120Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 21:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Auto Source Switching & Recovery
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 990 Watt
- Power Consumption (On mode)
- 715 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 1044 kWh
- Dimensions (WxDxH) - without stand
- 248.97 cm x 10.51 cm x 107.32 cm
- 108.8 kg
- Product Type
- Energy Class
- Class D
- 990 Watt
- 715 W
- 1044 kWh
- Diagonal Class
- 105"
- Commercial Use
- Series
- QMD Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 248.97 cm
- 10.51 cm
- 107.32 cm
- 108.8 kg
Display
- Resolution
- 5120 x 2160
- Display Format
- 5K UHD (2160p)
- 21:9
- Direct-lit LED
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1595 x 0.4785mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Certified for 16/7 Continuous Operation
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 1600 x 600 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 30 Watt
- Speakers
- 2 x main channel speaker - 15 Watt
- Connector Type
- Remote control/ambient sensor input , 3 x HDMI input , 3 x DisplayPort input , Multiple Display Control , Remote control output , Serial input , Serial output , VGA input , Audio line-in , Audio line-out , USB 2.0 , DVI-D input
- Batteries
- Cables Included
- DisplayPort cable
- Plug and Play, DDC/CI, EMC Class A
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0 Watt
- Width (Shipping)
- 270 cm
- Depth (Shipping)
- 80 cm
- Height (Shipping)
- 136 cm
- Weight (Shipping)
- 157.7 kg
- 0 °C
- 40 °C
- 10 - 80%
