Today's businesses, including banks, restaurants, retailers and more, are increasingly using digital signage to engage, educate and serve their customers. Commercial digital signage usage continues to increase, and, because of its ability to offer clearer text and images, UHD has become the next big thing in display technology. With the UHD technology, businesses can leverage the next generation of ultimate picture quality for conveying more impactful messaging and information. UHD offers ultra-realistic detail, the ability to display more information on one screen, and four times the detail clarity, which is most evident when displaying text. For commercial applications, essential features, such as portrait mode and longer operational hours, are combined with UHD clarity for the ultimate commercial display.
Bring the next generation of UHD picture quality to your commercial environment
Today's businesses, including banks, restaurants, retailers and more, are increasingly using digital signage to engage, educate and serve their customers. Commercial digital signage usage continues to increase, and, because of its ability to offer clearer text and images, UHD has become the next big thing in display technology. With the UHD technology, businesses can leverage the next generation of ultimate picture quality for conveying more impactful messaging and information. UHD offers ultra-realistic detail, the ability to display more information on one screen, and four times the detail clarity, which is most evident when displaying text. For commercial applications, essential features, such as portrait mode and longer operational hours, are combined with UHD clarity for the ultimate commercial display. -
UHD display QMF which designed for a commercial environment
The UHD line-up is designed to deliver superior image quality in all environments. The versatile range of displays is specially configured to suit any business application. The UHD displays deliver a super-crisp image with high pixel density that is perfect for displaying even the smallest details of photos and videos in a hyper-realistic and immersive visual experience. Non-glare panels come as standard to ensure outstanding performance in bright conditions. Boasting a narrow-bezel configuration, the standalone displays offer a compact solution to environments limited by space or lighting. The unique bezel design helps drive clear, uninterrupted viewing. -
Attract customers and improve brand identity with UHD lifelike images and picture quality
QMF Series delivers four times the FHD resolution on the same screen area, resulting in accurate recreation of details. Text that displays on QMF Series in UHD is super-crisp due to its high pixel density. High-detail visuals, such as photos and videos, are visible with the smallest details for a hyper-realistic and immersive visual experience. -
Display four times the FHD content on a single multiscreen for greater visual impact
You can provide more information through a smaller number of displays. UHD offers four times the resolution of FHD, which means that you can display the equivalent of four FHD content screens on a single UHD screen. QMF Series features a wide array of connectivity options, including the ability to display content from four separate input devices on the same screen without the need to first merge the content on a separate PC. With QMF Series, no special third-party components are required.
- Samsung QM55F QM-F Series - 55" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Motion Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- DVI, DisplayPort
- LCD Backlight Technology
- LED backlight - edge-lit
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Auto Source Switching & Recovery
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 165 Watt
- Power Consumption (On mode)
- 110 W
- Energy Consumption per Year
- 161 kWh
- Dimensions (WxDxH) - without stand
- 123.53 cm x 3.68 cm x 71.04 cm
- 16.8 kg
- Product Type
- Energy Class
- Class A
- 165 Watt
- 110 W
- 161 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- QM-F Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Dimensions
- Without stand
- 123.53 cm
- 3.68 cm
- 71.04 cm
- 16.8 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Coating
- Anti-glare
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, d-LED BLU, Mega Dynamic Contrast Ratio, SBB (attachable)
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-I input , 2 x DisplayPort input , 4 x HDMI input , Service , Audio line-in , Audio line-out , Serial input , Serial output , LAN , Infrared input , Infrared output
- Included Accessories
- Batteries
- Plug and Play, EMC, IP5X
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
- 0 Watt
- Width (Shipping)
- 133.5 cm
- Depth (Shipping)
- 18.2 cm
- Height (Shipping)
- 81.2 cm
- Weight (Shipping)
- 22.4 kg
- 0 °C
- 40 °C
- 10 - 80%
