Samsung ProXpress M4580FX Mono Laser Multifunction Printer
CALL YOUR ACCOUNT MANAGER FOR PRICING!
Quicklinx: B2ZHWS00 Mfr#: SL-M4580FX/SEE
Samsung's SMART ProXpress M4580FX monochrome multifunction printer provides smart usability that allows users to work fast and efficiently with intuitive, easy-to-use controls, high performance and resource-efficient features.
  • Enjoy preloaded applications and widgets
    It’s all about convenience and flow. Your favorite applications such as Copy, Scan / Send, Box, Job Status, Address Book and Help come preloaded while custom widgets provide instant access to frequently used functions.
  • Stand out with sharp, high-quality print output
    Samsung’s unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out.
  • Touch to print, just like on a tablet
    Innovation and usability is built into the SMART ProXpress M4580FX. The Samsung SMART UX Center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android-based devices.
  • Faster scanning and fuss-free printing
    The SMART ProXpress M4580FX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 35 single-sided image per minute (ipm) and a 1 GHz dual-core CPU that powers printing at 45 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently.
  • Save resources with low TCO printing
    Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 30000 standard B&W pages and drums that yield 100000 will lower your TCO and reduce waste.
  • eXtensible open architecture (XOA)
    The XOA web platform supports an array of server-based productivity solutions. From the UI, users can tap into a robust lineup of web-connected solutions. From the server, printer network managers can easily install and manage custom solutions tailored for your business.
  • SMART Manage
    Enhance the UI by arranging and managing the environment by user with My Page. Simply customize the My Page settings and Quick Menu for each user and you can keep track of an individual’s usage, control accessibility and more. Administrators can also create quick custom apps directly on the devices.
Samsung ProXpress M4580FX - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
2000 - 10000 pages
Max Copying Speed
Up to 35 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 600 x 600 dpi
Scanning
1200 x 1200 dpi
Display
10.1"
Original Size
105 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, cotton paper, punched paper, preprinted paper, archive paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, Business Core Printing Solutions (BCPS), Samsung SMART UX Centre, XOA (eXtensible Open Architecture) Web Platform
53 cm x 45.95 cm x 64.9 cm
30.2 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
200000 pages
2000 - 10000 pages
Display Diagonal Size
10.1"
Display Features
Touch screen
Standard Memory
1 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 35 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy, Image Repeat, Poster Copy, Edge Erase, proof copy, mirror image
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Broadcast Transmission
500 stations
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, on hook dial, last number redial
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
500 sheets
Paper cassette - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets , ADF - 50 sheets size: 105 x 148 mm - Legal (216 x 356 mm)
Speed Details
Printing: up to 45 ppm (A4) - B/W , Printing: up to 47 ppm (Letter A) - B/W , Copying: up to 35 ppm (A4) - B/W , Copying: up to 36 ppm (Letter A) - B/W , Scanning: up to 60 ipm - B/W duplex , Scanning: up to 35 ipm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Android, Apple Mac OS X 10.5 - 10.9
900 Watt
Power Consumption Sleep
1.8 Watt
First Copy Out Time B/W
6.5 sec
Consumables Included
1 x toner cartridge (black) - up to 7000 pages
ENERGY STAR Certified
53 cm
45.95 cm
64.9 cm
30.2 kg
Sound Emission
30 dBA (idle) / 56 dBA (operating)
