The robust ProXpress M4070FR features print speeds of up to 42 ppm. Powered by a Cortex-A5 core processor, it delivers unsurpassed performance for business applications. And with a Duplexing Automatic Document Feeder (DADF) able to process pages at up to 24 ipm, scan and copy jobs are a breeze. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency.
With 4-in-1 capability including print, copy, scan and fax and built-in duplex printing you can be sure the ProXpress M4070FR provides your business the versatility you need to stay competitive.
The ProXpress M4070FR employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also offers several different cartridges options from standard-yield laser toner cartridges that typically yield 3,000 standard pages to ultra-high yield laser toner cartridges that can yield up to 15,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs.
High speed printing and image processing
The robust ProXpress M4070FR features print speeds of up to 42 ppm. Powered by a Cortex-A5 core processor, it delivers unsurpassed performance for business applications. And with a Duplexing Automatic Document Feeder (DADF) able to process pages at up to 24 ipm, scan and copy jobs are a breeze. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency. -
4-in1 multifunction with automatic duplex
With 4-in-1 capability including print, copy, scan and fax and built-in duplex printing you can be sure the ProXpress M4070FR provides your business the versatility you need to stay competitive. -
Higher-quality print output
ReCP technology improves the readability of printed documents by enhancing thin lines and sharpening the edges of fine text. Small text that typically may not scan completely is sharpened through edge resolution enhancement, and half-tone patterns are removed to produce smooth images without visual artifacts. The ProXpress M4070FR delivers sharp, solid prints with effective output print resolutions of up to 1,200 x 1,200 dpi. -
Additional printing choices for professional documents
The printers' multipurpose tray supports media of up to 58 pounds weight, which offers more printing choices for professional documents. Labels, cards, covers and envelopes can be printed using the multi-purpose tray with ease. This ability virtually eliminates the time it takes to feed sheets one at a time. -
One touch eco button
Businesses can lower toner and paper usage with the one touch eco button. The one touch eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides), as well skipping blank pages and printing in toner save mode. The default eco settings can be adjusted using easy printer manager, and administrators can even enforce some or all of these rules in order to save your business money. -
Central print usage control to save more resources
Central print usage control, activated through the SyncThru admin job accounting feature, enables managers to assign users to specific printers, as well as assigning individual users or workgroups quotas. Tight usage controls as well as automatic notifications help business control costs and drive down spending. -
More laser toner cartridge options, more choices for cost reduction
The ProXpress M4070FR employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also offers several different cartridges options from standard-yield laser toner cartridges that typically yield 3,000 standard pages to ultra-high yield laser toner cartridges that can yield up to 15,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs. -
Convenient mobile printing optimized for various business environment
With the Samsung mobile print app, you and your employees can easily print from their mobile devices, at no additional cost. Users do not need to install a new driver or configure network settings. By simply downloading the Mobile Print app from the Google play store for Android or the App Store for iOS, and connecting to the Wi-Fi network on which the ProXpress M4070FR is shared, users can begin printing with ease. -
Easy printer manager
The easy printer manager helps companies remotely control settings, such as the one touch eco button, and easily access notifications and device status from one convenient location. Multiple devices can be monitored and managed using the easy printer manager. Businesses can also monitor printer status, such as error messages, including paper empty, toner empty and paper jam alerts. -
Easy secure printing
The ProXpress M4070FR features easy secure printing with a built-in numeric keypad, which allows users to protect personal or confidential documents. Users can select a secure print job through their driver, or administrators can force all jobs to require authentication. Once a secure print job is sent, it will only release when the user walks up and types in their PIN at the printer. This feature can protect sensitive documents from prying eyes, or reduce the number of wasted prints if a user decides not to pick up their print job. And best of all, this feature is included at no additional cost.
- Samsung ProXpress M4070FR - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 100000 impressions
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 820 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network
- 46.9 cm x 44.43 cm x 48.21 cm
- 17.07 kg
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 4 lines
- Interface
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
- Hard Disk Drive
- 4 GB
Copying
- Max Copying Speed
- Up to 40 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, IBM Proprinter, SPL, PDF
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 209 stations
- Delayed Transmission
- Fax forwarding, automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- 300 sheets
- 820 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 42 ppm (Letter A) - B/W , Copying: up to 40 ppm (A4) - B/W , Copying: up to 42 ppm (Letter A) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB - 4 pin USB Type A
- Operating System Support
- MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
- 700 Watt
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- ISO/IEC 19752
- 46.9 cm
- 44.43 cm
- 48.21 cm
- 17.07 kg
- Sound Emission
- 26 dBA (idle) / 58 dBA (operating)
