Discover printing solutions designed to ignite your productivity. The ProXpress C2670FW A4 Color Multifunction Laser Printer features Near Field Communication (NFC), so you can tap, print and go. An intuitive touch screen provides ease of use, while print, copy, scan and fax capability delivers versatility.
Higher quality print output
Samsung's Rendering Engine for Clean Page (ReCP) technology, up to 9,600 x 600 dpi effective output and polymerized toner improve the overall quality and vibrancy of your color printing. Graphics and text are brought into sharper focus, while solid objects are overlapped to eliminate white gaps. -
High-speed printing and image processing
Achieve print speeds of up to 27 pages per minute (ppm). The 533 MHz dual-core processor, combined with 512 MB standard memory (expandable up to 1 GB), reduces completion time for even the heaviest print and copy jobs. So your business can speed up document processing to drive efficiency. -
A wide range of media handling
The printers' multipurpose tray supports media of up to 220 gsm (grams per square meter) in weight, offering more printing choices. Numerous labels, cards and envelopes can be printed using the multipurpose tray, virtually eliminating the time it takes to feed sheets one at a time.
- Samsung ProXpress C2670FW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 60000 pages
- Max Copying Speed
- Up to 26 ppm (mono) / up to 26 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, glossy paper, cotton paper, punched paper, archive paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 820 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder
- 46.9 cm x 45.25 cm x 50.43 cm
- 26.62 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 60000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB
- Max Supported Memory
- 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PostScript 3, SPLC, PDF 1.7, PCL 6C, PCL 5ce
- First Print Out Time B/W
- 17 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Fax forwarding, multi-send, delayed sending
Document & Media Handling
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 820 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets , Paper cassette - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - colour , Printing: up to 27 ppm (Letter A) - colour , Copying: up to 26 ppm (A4) - B/W , Copying: up to 27 ppm (Letter A) - B/W , Copying: up to 26 ppm (A4) - colour , Copying: up to 27 ppm (Letter A) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Operating System Support
- MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.4 - 10.8
- 500 Watt
- Power Consumption Standby
- 18 Watt
- Power Consumption Sleep
- 2.48 Watt
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 19 sec
- Included Accessories
- 4 GB SD memory card
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- ENERGY STAR Certified
- 46.9 cm
- 45.25 cm
- 50.43 cm
- 26.62 kg
- Sound Emission
- 37 dBA (idle) / 56 dBA (operating)
