Samsung PM43H 43" 1920x1080 DVI VGA HDMI DP LCD Large Format Display
Quicklinx: DR51WS00 Mfr#: LH43PMHPBGC/EN
  • 1080p
Samsung's TIZEN-powered PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting. Additionally, the PMH series displays achieve robust, 24/7 durability for dependable and uninterrupted operations. As a result, businesses can feel confident that their messages will be delivered exactly as intended anywhere and at any time.
The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. Equipped with a non-glare frontal panel, the PMH series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
  • Durable premium displays optimize operations and message quality in any environment
  • Convenient display control through a centralized receiver
  • Brilliant, glare-free visual quality
Samsung PM43H PMH Series - 43" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, DisplayPort
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Mega Dynamic Contrast Ratio
USB
2 ports
Voltage
Energy Class
Class G
154 Watt
Power Consumption (On mode)
135 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
180 kWh
96.4 cm x 3.05 cm x 55.43 cm
9.5 kg
Energy Class
Class G
154 Watt
135 W
135 kWh/1000h
180 kWh
Diagonal Class
43"
Commercial Use
Series
PMH Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Dimensions
Without stand
96.4 cm
3.05 cm
55.43 cm
9.5 kg
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
3000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
MagicInfo
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Wi-Fi
Connector Type
2 x HDMI , DisplayPort input , DVI-I input , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , Remote control input
EMC Class A
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
107.7 cm
Depth (Shipping)
15.4 cm
Height (Shipping)
66.1 cm
Weight (Shipping)
12.5 kg
10 - 80% (non-condensing)
