Samsung PIM-HDbaseT T-Plug in Receiver
Quicklinx: BWZ6WS00 Mfr#: SBB-HRCA/EN
Samsung's PIM-HDBT LFD HDBaseT plug-in receiver helps to make LFD installations significantly simpler and less costly. Working with Samsung's LFDs which support the PIM module, the receiver enables all-in-one connectivity between HD video sources and remote displays through a single cable, delivering uncompressed HD video, audio, Ethernet and control signals.
Samsung PIM-HDBT - video/audio/network extender - HDBaseT
Video/audio/network extender
Plug-in module
HDBaseT
Max Transfer Distance
100 m
20 cm x 3.44 cm x 17.56 cm
1.2 kg
Samsung DH40D, DH48D, DH55D, DM65D, DM75D, ED65C, ED75C, ED75D, ME95C
Plug-in module
Wired
HDBaseT
100 m
1 x network - RJ-45 female , 1 x HDBaseT - RJ-45 female
20 cm
3.44 cm
17.56 cm
1.2 kg
10 °C
10 - 80%
