Samsung PE46C 46" 1920x1080 8ms DVI-D HDMI DisplayPort E-LED System on Chip Large Format Display
Quicklinx: 8YK0WS00 Mfr#: LH46PECPLBC/EN
  • 1080p
Convey the right message in a highly efficient, controllable, and cost-effective manner with Samsung PE series premium signage displays. Start capturing your audience immediately to increase your business performance. Designed for companies that require a superior digital signage solution in high-traffic areas which do not compromise on quality and performance, Samsung PE series premium signage displays enable continuous, high-quality content presentation in any environment. Equipped with Samsung's powerful and exclusive SSSP technology using dual-core CPU, and a combination of media player and integrated display solution, MagicInfo premium S player, the Samsung PE series can deliver multiple types of content seamlessly to your audience. Watch your display management productivity go up as your total cost of ownership goes down with this all-in-one display.
  • An integrated solution to provide a digital signage experience
    The Samsung Smart Signage Platform (SSSP) is embedded within Samsung displays, providing the power of a dual-core CPU and a combination of media player and integrated display solution, MagicInfo premium S player. The solution eliminates the need for additional PC modules while reducing installation and maintenance issues. Using the included MagicInfo premium S player, businesses can create, schedule, and deploy content effortlessly. Multiple types of content can be streamed simultaneously and continuously courtesy of the dual-core CPU and large storage, and a high performance video processor integrated on a single chip. Save more by paying less for a display integrated with a media player and premium management solution.
  • Adaptable and economical business display
    These durable displays offer lower total cost of ownership (TCO), and are designed for continuous, energy-efficient operation with reduced power consumption and heat emission. The PE series LFDs incorporate an innovative backlight unit (BLU), saving more electricity than traditional devices and lowering operational expenditure. This LED technology also reduces environmental impact by cutting out potentially harmful substances such as mercury, halogen and lead, as does the spray-free injection molding used to produce flat panel displays.
  • 24/7 performance with enhanced quality
    A diverse range of businesses can optimize the appearance of their content and image with the PE series, improving key messages and offering a unified brand identity. Its slim bezel and edge-LED technology offer high brightness, with an enhanced luminescence of 700 nit. The viewing experience is further improved by an anti-glare, anti-glossy panel. The PE series represent highly durable displays that are designed for operation 24/7 in a variety of challenging environments.
  • Easy installation and efficient space usage
    Improve business display management with the slim, lightweight design of the Samsung PE series. This attractive LFD ensures easy installation and improved space management, leaving more room available for other purposes. Content can be delivered to heights of up to 15 m thanks to the DisplayPort feature. Furthermore, remote control is ensured by RJ45 port utilization, even when users are combining RJ45 and RS-232 connections.
  • Slim and lightweight for flexible installation
    The PE Series has an extremely slim depth, which is 73 per cent reduced compared to traditional products, giving a sleeker overall appearance. The lightweight design frees up more space and leads to easier, more efficient installation. A narrow bezel increases viewer focus on content and allows more room for information display. It also enables virtually seamless video walls for a more immersive experience.
Samsung PE46C PE Series - 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Remote control
Voltage
Energy Class
Class B
187 Watt
Power Consumption (On mode)
110 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
161 kWh
105.45 cm x 3.51 cm x 60.85 cm
16.4 kg
Energy Class
Class B
187 Watt
110 W
161 kWh
Diagonal Class
46"
Commercial Use
Series
PE Series
Video Processor
Dual-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
PC Interface
HDCP Compatible
Dimensions
Without stand
105.45 cm
3.51 cm
60.85 cm
16.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.17675 x 0.53025mm
Response Time
8 ms
Commercial Features
Certified for 24/7 Continuous Operation, MagicInfo
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , DisplayPort , Composite video / component video input , HDMI input , Audio line-in , Audio line-out
VGA cable
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
1 Watt
Width (Shipping)
114.1 cm
Depth (Shipping)
14 cm
Height (Shipping)
71.9 cm
Weight (Shipping)
20.1 kg
10 - 80%
