Product
Brand
Samsung OTG 32GB Flash Drive USB 3.0/Micro USB 2.0
Quicklinx: BLKLWS00 Mfr#: MUF-32CB/EU
Samsung's UFD (USB Flash Drive) is a USB 3.0 mass storage media that is specifically designed to meet the capacity, performance and stylish figuration inherent in newly emerging Desktop computer, Notebook and any other electronic devices with a USB port. Samsung's UFD assorted high capacity and performance can store the data that the user wants to keep safely and quickly. For an easy adoption, Samsung's UFD can be operable in modern operating systems such as Windows, Mac OS, Linux and other systems. And it’s compatible with any device that uses a USB 3.0 port and furthermore, it can support backward compatibility with USB 2.0 port.
Samsung DUO MUF-32CB - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0 / micro USB
Storage Capacity
32 GB
NAND Flash
5 years warranty
USB flash drive
Storage Capacity
32 GB
Compatibility
Non-specific
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0 / micro USB
NAND Flash
Shockproof, magnetic-proof, water resistant, X-ray-proof, USB and micro-USB Dual connector
Limited warranty - 5 years
36.61 mm
5.73 mm
16.05 mm
5.2 g
60 °C
