Samsung OMD-K High Brightness Display provides easily readable text and bright graphics in high ambient light environments and outdoor applications, along with all-weather durability when installed in a customized housing. And with the SMART Signage Platform, you can manage your content without external devices.
High brightness
At 2500 nits, the OMD-K LED display delivers high brightness for excellent legibility and visibility, even in high ambient light environments. -
Handle outdoor locations and high ambient light
This display provides easily readable text and bright graphics in high ambient light and outdoor locations. With the included panel kit for installing the display in a custom-built enclosure, it can fully perform in heat, cold, rain, snow and dust. VESA compliance allows for easy mounting inside the custom enclosure. -
Circular polarizing technology
Samsung's circular polarizing technology allows for viewing content on the display while wearing polarized sunglasses. -
SMART Signage Platform offers a fully embedded solution that eliminates the need for additional external devices. System on Chip (SoC) delivers media player functionality, and content is easily controlled through Samsung MagicInfo software. -
Flexible connectivity
Get access to content from a variety of sources. Connections include PC (VGA), Digital (Display Port, HDMI and DVI), embedded Wi-Fi, RS232C for external control capability and an SD card slot. -
Perfect for various industries
Samsung OMD-K High Brightness Display is perfect for transportation hubs, banking offices, retail storefront windows, sports arenas, convention centers, drive-through menu boards and many more applications.
- Samsung OM46D-K 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 395 Watt
- Power Consumption (On mode)
- 216 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 315 kWh
- Dimensions (WxDxH) - without stand
- 103.59 cm x 14.29 cm x 59.05 cm
- 18.7 kg
- Product Type
- Energy Class
- Class D
- 395 Watt
- 216 W
- 315 kWh
- Diagonal Class
- 46"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, brightness sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode
- Dimensions
- Without stand
- 103.59 cm
- 14.29 cm
- 59.05 cm
- 18.7 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
- Button lock
- Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo, anti-image retention, Smart Scheduling, MagicInfo Player-S2
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
- Cables Included
- VGA cable
- UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB 17625.1-2012, IEC60950-1, GB 4943.1-2011
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 112.3 cm
- Depth (Shipping)
- 23.6 cm
- Height (Shipping)
- 68.6 cm
- Weight (Shipping)
- 24.2 kg
- 0 °C
- 30 °C
- 10 - 80%
