Samsung OM24E 24" 1920x1080 VGA HDMI S-PVA Large Format Display
Quicklinx: BWYJWS00 Mfr#: LH24OMEPWBC/EN
  • 1080p
Samsung's compact, semi-outdoor signage solution provides business owners with a dynamic tool to deliver coherent messaging to prospective customers. Ideal for a window display in a retail shop, real estate agency or other service oriented business, OME displays can help increase sales by giving you another way to communicate your brand identity.
  • Leverage powerful imagery on a compact scale
    Samsung's small-sized semi-outdoor signage provides business owners with a dynamic approach to delivering a coherent and ultimately purchase-inducing message to consumers as a window display of retail shops, real estate agencies and other locations.
  • Deliver promotional messaging vividly with excellent visibility
    Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OM24E SMART Signage features 1500-nit high brightness and 4000:1 contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays.
  • Rely on strong 24/7 durability in various outdoor environments
    Present business messaging 24/7 even when the display is exposed to sunlight directly and indirectly for reliable around-the-clock operation. OM24E SMART Signage is mechanically designed and has undergone internal testing to endure heat with a panel that can withstand up to 110 °C (230 °F) temperatures.
Samsung OM24E 24" Class (23.8" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
24"
Diagonal Size
23.8"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery, Lamp Error Detection
Batteries, external brightness sensor
Voltage
Energy Class
Class D
Power Consumption (On mode)
67 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
98 kWh
54.92 cm x 5.8 cm x 31.91 cm
3.5 kg
Energy Class
Class D
67 W
98 kWh
Diagonal Class
24"
Diagonal Size
23.8"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
Dimensions
Without stand
54.92 cm
5.8 cm
31.91 cm
3.5 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
100000:1
Brightness
1500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, security lock slot (cable lock sold separately), Smart Scheduling, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Audio System
Built-in speaker
Connector Type
HDMI input , Audio line-in , VGA input , Audio line-out
Security Slot Type
Kensington security slot
VGA cable
Plug and Play, TUV, GOST, EN55022, NEMKO, PCBC, SASO, SIQ, CCC, PSB, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, KC, NOM-019-SCFI-1998, K60950-1, GB 4943.1-2011
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
65.1 cm
Depth (Shipping)
13.9 cm
Height (Shipping)
39 cm
Weight (Shipping)
4.8 kg
50 °C
10 - 80%
