Samsung's compact, semi-outdoor signage solution provides business owners with a dynamic tool to deliver coherent messaging to prospective customers. Ideal for a window display in a retail shop, real estate agency or other service oriented business, OME displays can help increase sales by giving you another way to communicate your brand identity.
Leverage powerful imagery on a compact scale
Samsung's small-sized semi-outdoor signage provides business owners with a dynamic approach to delivering a coherent and ultimately purchase-inducing message to consumers as a window display of retail shops, real estate agencies and other locations. -
Deliver promotional messaging vividly with excellent visibility
Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OM24E SMART Signage features 1500-nit high brightness and 4000:1 contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays. -
Rely on strong 24/7 durability in various outdoor environments
Present business messaging 24/7 even when the display is exposed to sunlight directly and indirectly for reliable around-the-clock operation. OM24E SMART Signage is mechanically designed and has undergone internal testing to endure heat with a panel that can withstand up to 110 °C (230 °F) temperatures.
- Samsung OM24E 24" Class (23.8" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 24"
- Diagonal Size
- 23.8"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- S-VA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Auto Source Switching & Recovery, Lamp Error Detection
- Included Accessories
- Batteries, external brightness sensor
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- Power Consumption (On mode)
- 67 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 98 kWh
- Dimensions (WxDxH) - without stand
- 54.92 cm x 5.8 cm x 31.91 cm
- 3.5 kg
- Product Type
- Energy Class
- Class D
- 67 W
- 98 kWh
- Diagonal Class
- 24"
- Diagonal Size
- 23.8"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode
- Dimensions
- Without stand
- 54.92 cm
- 5.8 cm
- 31.91 cm
- 3.5 kg
Display
- LCD Display Technology
- S-VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 100000:1
- Brightness
- 1500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, security lock slot (cable lock sold separately), Smart Scheduling, MagicInfo Player-S3
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm
Audio System
- Built-in speaker
- Connector Type
- HDMI input , Audio line-in , VGA input , Audio line-out
- Security Slot Type
- Kensington security slot
- Cables Included
- VGA cable
- Plug and Play, TUV, GOST, EN55022, NEMKO, PCBC, SASO, SIQ, CCC, PSB, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, KC, NOM-019-SCFI-1998, K60950-1, GB 4943.1-2011
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 65.1 cm
- Depth (Shipping)
- 13.9 cm
- Height (Shipping)
- 39 cm
- Weight (Shipping)
- 4.8 kg
- 0 °C
- 50 °C
- 10 - 80%
