Samsung's OL46B is an all-in-one outdoor display and enclosure designed to ensure flawless performance for outdoor high-impact business communications.
- Samsung OL46B 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Included Accessories
- Remote control
- Microsoft Certification
- Compatible with Windows 7
- 395 Watt
- Power Consumption Stand by
- 2 Watt
- 61.42 cm x 61.85 cm x 173 cm
- Product Type
- 395 Watt
- Diagonal Class
- 46"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- 61.42 cm
- 61.85 cm
- 173 cm
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 1500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Response Time
- 8 ms
- Certified for 24/7 Continuous Operation
Stands & Mounts
- Stand
- Included
- Stand Features
- Swivel
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Connector Type
- VGA input , DVI-D input , DisplayPort , Composite video input , HDMI , Audio line-in , Audio line-in , Audio line-out , Remote control , Remote control
- Cables Included
- VGA cable
- EN55022, EN55024, IEC 60529 IP56
- Power Device
- Power supply
- Power Consumption Stand by / Sleep
- 1 Watt
- 2 Watt
- Weight (Shipping)
- 108 kg
