Designed for businesses such as retail stores, transportation outlets and Quick Service Restaurants (QSRs), Samsung OHD series SMART signage delivers a premium signage solution that can increase brand awareness, improve traffic and enhance revenue. These high-brightness, high-contrast displays provide exceptionally clear picture quality, even in bright environments, while maximizing durability in harsh conditions, 24/7. OHD series displays also employ energy efficient technology to minimize the increased power consumption of a high-brightness screen, and they come equipped with advanced connectivity technology that enables convenient display management in remote locations.
Richly deliver business messaging in outdoor environments with high brightness and picture quality
Enhance brand recognition, increase the flow of customer traffic and boost income with bright, vivid displays that keep viewers focused on the business message. Enthrall and mesmerize customers with high brightness that enhances readability in outdoor daylight conditions. Deliver super dynamic visibility outdoors through a high contrast ratio, which enables the display to show content more vividly and crisply with each and every detail and true, deep black hues. -
Rely on strong 24/7 durability in virtually any environment
Present business messaging 24/7 even when the signage is exposed to direct or indirect sunlight, or to harsh environmental conditions such as dust, water and heat. OHD series SMART signage is mechanically designed to endure high temperatures that can withstand a wide operating range of temperature variation. Enhanced anti-vandalism technologies prevent breaks, scratches and defacement to optimize the signage for outdoor usage. -
Display content with optimal brightness and cost-efficiency
Optimize brightness control while reducing display operating expenses and power consumption with an automatic brightness sensor. Customize the maximum and minimum brightness to complement any environment and adjust brightness levels both manually or automatically as needed. Control expenses by saving energy and extending the life of the displays to minimize TCO with the auto brightness sensor. -
Elevate the display environment with a sleek, sophisticated design
Open a great world of usage applications and elegance with a slim depth that provides a sleeker enclosure design. OHD series SMART signage features a stunning slim display depth to impress customers and reduce viewing distractions. And, the slim-depth panels enable the stylish displays to efficiently use available space while reducing separate housing design costs.
- Samsung OH46D OHD Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- HDCP Compatible
- Technology
- S-VA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, Auto Source Switching & Recovery, Lamp Error Detection, SMART Signage Platform 2nd Generation, Smart SoC Built-in Signage
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- Power Consumption (On mode)
- 193 W
- Energy Consumption per Year
- 282 kWh
- 106.9 cm x 9.03 cm x 62.36 cm
- 39.5 kg
- Product Type
- Energy Class
- Class D
- 193 W
- 282 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- OHD Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Protection
- Protection glass
- 106.9 cm
- 9.03 cm
- 62.36 cm
- 39.5 kg
Display
- LCD Display Technology
- S-VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 100000:1
- Brightness
- 3000 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
- Pivot, Multiple Display Control (MDC), anti-image retention, Auto Brightness Control, MagicInfo S
Stands & Mounts
- Stand
- Optional
Remote Control
- Remote control
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 2 x HDMI input , HDBaseT output , Audio line-out
- IEC 60529 IP56
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 117.4 cm
- Depth (Shipping)
- 30.5 cm
- Height (Shipping)
- 72.7 cm
- Weight (Shipping)
- 54.4 kg
- -35 °C
- 50 °C
- 10 - 80%
