Product
Samsung OH46D-K 46" 1920x1080 VGA DVI HDMI DP WiFi LED LFD
Quicklinx: BKQFWS00 Mfr#: LH46OHDPKBC/EN
  • 1080p (Full HD)
Designed for businesses such as retail stores, transportation outlets and Quick Service Restaurants (QSRs), Samsung OHD series SMART signage delivers a premium signage solution that can increase brand awareness, improve traffic and enhance revenue. These high-brightness, high-contrast displays provide exceptionally clear picture quality, even in bright environments, while maximizing durability in harsh conditions, 24/7. OHD series displays also employ energy efficient technology to minimize the increased power consumption of a high-brightness screen, and they come equipped with advanced connectivity technology that enables convenient display management in remote locations.
  • Richly deliver business messaging in outdoor environments with high brightness and picture quality
    Enhance brand recognition, increase the flow of customer traffic and boost income with bright, vivid displays that keep viewers focused on the business message. Enthrall and mesmerize customers with high brightness that enhances readability in outdoor daylight conditions. Deliver super dynamic visibility outdoors through a high contrast ratio, which enables the display to show content more vividly and crisply with each and every detail and true, deep black hues.
  • Rely on strong 24/7 durability in virtually any environment
    Present business messaging 24/7 even when the signage is exposed to direct or indirect sunlight, or to harsh environmental conditions such as dust, water and heat. OHD series SMART signage is mechanically designed to endure high temperatures that can withstand a wide operating range of temperature variation. Enhanced anti-vandalism technologies prevent breaks, scratches and defacement to optimize the signage for outdoor usage.
  • Display content with optimal brightness and cost-efficiency
    Optimize brightness control while reducing display operating expenses and power consumption with an automatic brightness sensor. Customize the maximum and minimum brightness to complement any environment and adjust brightness levels both manually or automatically as needed. Control expenses by saving energy and extending the life of the displays to minimize TCO with the auto brightness sensor.
  • Elevate the display environment with a sleek, sophisticated design
    Open a great world of usage applications and elegance with a slim depth that provides a sleeker enclosure design. OHD series SMART signage features a stunning slim display depth to impress customers and reduce viewing distractions. And, the slim-depth panels enable the stylish displays to efficiently use available space while reducing separate housing design costs.
Samsung OH46D OHD Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
HDCP Compatible
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Auto Source Switching & Recovery, Lamp Error Detection, SMART Signage Platform 2nd Generation, Smart SoC Built-in Signage
Remote Control
Standard remote
Voltage
Energy Class
Class D
Power Consumption (On mode)
193 W
Energy Consumption per Year
282 kWh
106.9 cm x 9.03 cm x 62.36 cm
39.5 kg
Energy Class
Class D
193 W
282 kWh
Diagonal Class
46"
Commercial Use
Series
OHD Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Portrait mode, landscape mode
Protection
Protection glass
106.9 cm
9.03 cm
62.36 cm
39.5 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
100000:1
Brightness
3000 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Commercial Features
Pivot, Multiple Display Control (MDC), anti-image retention, Auto Brightness Control, MagicInfo S
Stands & Mounts
Stand
Optional
Remote Control
Standard remote
Network & Internet Multimedia
LAN
Connector Type
2 x HDMI input , HDBaseT output , Audio line-out
IEC 60529 IP56
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
Width (Shipping)
117.4 cm
Depth (Shipping)
30.5 cm
Height (Shipping)
72.7 cm
Weight (Shipping)
54.4 kg
-35 °C
50 °C
10 - 80%
