Samsung's small and versatile outdoor signage allows businesses to tap into a world of customer engagement. By showcasing compelling and entertaining content, you can monetize and leverage customer attention at ATMs, gas pumps and other locations that people encounter throughout their day.
High brightness & high contrast ratio
Enhance brand recognition, increase the flow of customer traffic and boost income with bright, vivid displays. Hold customers' attention with high brightness screens, which enhance readability in outdoor daylight conditions. Offering excellent contrast, these super dynamic displays ensure maximum visibility outdoors, guaranteeing that you will provide vivid images with deep black hues. -
Reflection canceling protection glass
Ensure your message is legible in almost any lighting condition with Reflection Canceling technology. By reducing reflection, this technology prevents glare in outdoor environments, even under direct sunlight. -
Superior, 24/7 durability in demanding conditions
Present business messaging 24/7 - even when the display is exposed to direct or indirect sunlight - for reliable around-the-clock operation. -
Steady Cooling System
Samsung's advanced Steady Cooling System (SCS) ensures stable operation and fast display startup with advanced thermal control. By eliminating the need for additional air-conditioning or heating equipment, SCS has made it possible for OHE displays to fit inside a slim form factor while still operating in a wide range of temperatures. -
Auto brightness sensor
Optimize visibility and product lifespan while reducing power consumption with Samsung's automatic brightness sensor. With this function, you can set the automatic maximum and minimum brightness to match any environment or adjust brightness levels manually as you see fit.
- Samsung OH24E 24" Class (23.8" viewable) LED-backlit LCD display - Full HD - outdoor - for digital signage
- Product Type
- LED-backlit LCD flat panel display with built-in PC - outdoor
- Diagonal Class
- 24"
- Diagonal Size
- 23.8"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- HDCP Compatible
- Technology
- S-VA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, Lamp Error Detection, SMART Signage Platform 3nd Generation
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- Power Consumption (On mode)
- 67 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 98 kWh
- 56.32 cm x 6.64 cm x 33.32 cm
- 10.6 kg
- Product Type
- Energy Class
- Class D
- 67 W
- 98 kWh
- Diagonal Class
- 24"
- Diagonal Size
- 23.8"
- Commercial Use
- Combined With
- Built-in PC
- Outdoor
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- HDCP Compatible
- Modes
- Portrait mode
- Design
- Rugged design
- Protection
- Dustproof, protection glass, water-resistant
- 56.32 cm
- 6.64 cm
- 33.32 cm
- 10.6 kg
Display
- LCD Display Technology
- S-VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-reflection
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 100000:1
- Brightness
- 1500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, security lock slot (cable lock sold separately), Smart Scheduling, Auto Brightness Control, MagicInfo Player-S3
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm
Media Player
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 Quad-Core ( 1.5 GHz ) - 1 GB DDR3 - 8 GB
- 8 GB
- Operating System
- Linux
Remote Control
- Remote control
- Connector Type
- HDMI input , Audio line-out , USB 2.0 , Serial input , Multiple Display Control
- Security Slot Type
- Kensington security slot
- Batteries
- TUV, C-Tick, GOST, EN55022, NEMKO, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60529 IP56, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, GB 4943.1-2011
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 67.8 cm
- Depth (Shipping)
- 15.3 cm
- Height (Shipping)
- 41.8 cm
- Weight (Shipping)
- 12 kg
- -30 °C
- 50 °C
- 10 - 80%
