Samsung OH24E 24" 1920x1080 HDMI S-PVA Large Format Display
Quicklinx: BWYKWS00 Mfr#: LH24OHEPKBB/EN
  • 1080p
Samsung's small and versatile outdoor signage allows businesses to tap into a world of customer engagement. By showcasing compelling and entertaining content, you can monetize and leverage customer attention at ATMs, gas pumps and other locations that people encounter throughout their day.
  • High brightness & high contrast ratio
    Enhance brand recognition, increase the flow of customer traffic and boost income with bright, vivid displays. Hold customers' attention with high brightness screens, which enhance readability in outdoor daylight conditions. Offering excellent contrast, these super dynamic displays ensure maximum visibility outdoors, guaranteeing that you will provide vivid images with deep black hues.
  • Reflection canceling protection glass
    Ensure your message is legible in almost any lighting condition with Reflection Canceling technology. By reducing reflection, this technology prevents glare in outdoor environments, even under direct sunlight.
  • Superior, 24/7 durability in demanding conditions
    Present business messaging 24/7 - even when the display is exposed to direct or indirect sunlight - for reliable around-the-clock operation.
  • Steady Cooling System
    Samsung's advanced Steady Cooling System (SCS) ensures stable operation and fast display startup with advanced thermal control. By eliminating the need for additional air-conditioning or heating equipment, SCS has made it possible for OHE displays to fit inside a slim form factor while still operating in a wide range of temperatures.
  • Auto brightness sensor
    Optimize visibility and product lifespan while reducing power consumption with Samsung's automatic brightness sensor. With this function, you can set the automatic maximum and minimum brightness to match any environment or adjust brightness levels manually as you see fit.
Samsung OH24E 24" Class (23.8" viewable) LED-backlit LCD display - Full HD - outdoor - for digital signage
LED-backlit LCD flat panel display with built-in PC - outdoor
Diagonal Class
24"
Diagonal Size
23.8"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
HDCP Compatible
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Lamp Error Detection, SMART Signage Platform 3nd Generation
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
USB
Remote control, batteries
Voltage
Energy Class
Class D
Power Consumption (On mode)
67 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
98 kWh
56.32 cm x 6.64 cm x 33.32 cm
10.6 kg
Energy Class
Class D
67 W
98 kWh
Diagonal Class
24"
Diagonal Size
23.8"
Commercial Use
Combined With
Built-in PC
Outdoor
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
HDCP Compatible
Modes
Portrait mode
Design
Rugged design
Protection
Dustproof, protection glass, water-resistant
56.32 cm
6.64 cm
33.32 cm
10.6 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
100000:1
Brightness
1500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, anti-image retention, security lock slot (cable lock sold separately), Smart Scheduling, Auto Brightness Control, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
USB Ports Qty
1
Configuration
ARM Cortex-A9 Quad-Core ( 1.5 GHz ) - 1 GB DDR3 - 8 GB
8 GB
Operating System
Linux
Remote Control
Remote control
Connector Type
HDMI input , Audio line-out , USB 2.0 , Serial input , Multiple Display Control
Security Slot Type
Kensington security slot
Batteries
TUV, C-Tick, GOST, EN55022, NEMKO, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60529 IP56, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, GB 4943.1-2011
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
67.8 cm
Depth (Shipping)
15.3 cm
Height (Shipping)
41.8 cm
Weight (Shipping)
12 kg
-30 °C
50 °C
10 - 80%
