Samsung NP540U3C-A02UK 13.3" Touchscreen i3-3217UM 6GB 500GB Win8
Quicklinx: 951BWS00 Mfr#: NP540U3C-A02UK
  • Core i3
  • Windows 8 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
2 on order, delivery delayed
Your laptop should cater to you, not the other way around! With the Samsung Series 5 Ultra, you have all the connectivity and ports that you need to get things done. From blazing fast USB, to a full size memory card reader, you have all the ports that you need. Don't let your laptop limit your creativity, let your laptop unleash it.
The blazing fast performance of solid state. The massive storage of a hard disk drive. Samsung ExpressCache combines both in one technologically advanced package.
  • Speed and storage come together with ExpressCache technology
  • Sleek and chic Samsung design for those on the go
    Ultra-light, ultra-thin and ultra-sleek, you'll never get tired of staring at the Series 5 Ultra. The Samsung Series 5 Ultra is amazingly portable and perfectly designed for a mobile life. Because it's remarkably thin and light it's easy to take it with you anytime and anywhere - so you'll always have your own office.
  • Amazing high definition display
    Samsung excels at picture quality. The razor-sharp high-definition LCD screen features SuperBright technology, for a brilliant 300-nit screen and stunning range of color. You can multi-task and get things done with ease and enjoy every little detail of your favorite pictures and films.
  • Enjoy your content wirelessly with WiDi
    The Intel Wireless Display (WiDi) brings all your photos, videos, online content, and more - right from this compact notebook and onto your big screen. Simply connect an adapter to your TV, follow a few simple steps to sync with your Samsung Series 5 Ultra, then sit back and enjoy your digital life with the great image quality and sound of your TV.
  • Connectivity without compromise
Samsung Series 5 Ultra 540U3C - 13.3" - Intel Core i3 3217U - 6 GB RAM - 500 GB HDD
Ultrabook
Operating System
Win 8 64-bit
Intel Core i3 (3rd Gen) 3217U / 1.8 GHz / 3 MB Cache
6 GB DDR3 (1 x 2 GB + 4 GB (soldered))
Storage
500 GB HDD / 5400 rpm + 24 GB SSD cache
Display
13.3" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
4-cell
Titan silver
31.51 cm x 21.89 cm x 1.99 cm
1.69 kg
Region: United Kingdom
Ultrabook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel HM76 Express
RAM
6 GB (1 x 2 GB + 4 GB (soldered))
DDR3 SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
SSD Cache
24 GB
Display
13.3"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
SuperBright
Audio & Video
Graphics Processor
Memory Allocation Technology
Dynamic Video Memory Technology
Camera
Resolution
1.3 Megapixel
Sound
Stereo speakers, microphone
SoundAlive
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Intel Centrino Advanced-N 6235
Network Interface
Gigabit Ethernet
4-cell lithium polymer
52 Wh
AC Adapter
Output
40 Watt
Connections & Expansion
Headphone/microphone combo jack , HDMI , 2 x USB 2.0 , USB 3.0 , LAN , Mini-VGA
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Norton Online Backup (30 days trial), SAMSUNG Support Center, Samsung Recovery Solution, Samsung Fast Start, Norton Internet Security (60 days trial), Fast Browsing, Samsung Easy Settings, S Player, S Gallery, S Camera, Samsung Fast Solutions
Titan silver
USB Sleep-and-charge ports, ExpressCache technology
Localization
1.69 kg
