It's all about convenience and flow. Your favorite applications such as copy, scan, send, box, job status, address book and help come preloaded while custom widgets provide instant access to frequently used functions.
Innovation and usability is built into the SMART MultiXpress M4370LX. The Samsung SMART UX center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android -based devices.
The SMART MultiXpress M4370LX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 55 single-sided image per minute (ipm) and a 1 GHz dual-core CPU that powers printing at 43 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently.
Enjoy preloaded applications and widgets
It's all about convenience and flow. Your favorite applications such as copy, scan, send, box, job status, address book and help come preloaded while custom widgets provide instant access to frequently used functions. -
Touch to print, just like on a tablet
Innovation and usability is built into the SMART MultiXpress M4370LX. The Samsung SMART UX center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android -based devices. -
Faster scanning and fuss-free printing
The SMART MultiXpress M4370LX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 55 single-sided image per minute (ipm). With high-performance speed printing, businesses can work smoothly and operate more efficiently. -
Stand out with sharp, high-quality print output
Samsung's unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out. -
Save resources with low TCO printing
Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 30000 standard B&W pages and drums that yield 100000 will lower your TCO and reduce waste. -
Expand use with independent functions and extensibility
The interface also provides the real preview function from preloaded applications such as copy, send and box. You can also get direct web access through the Android web browser to quickly print web content without a PC. -
Create the printing environment that suits your needs with partner solutions
Numerous certified partner solutions are available through the Samsung XOA platform for further customization. -
Samsung's Business Core Printing Solutions (BCPS)
Samsung's Business Core Printing Solutions (BCPS) work as efficiently as you do with secure, cost-effective print operations. These solutions require no dedicated server or IT resources and reduces unnecessary printing and supply use. -
Samsung wireless & NFC printing option
With Samsung wireless & NFC printing, you can simply tap your smart device to access various mobile printing solutions including user authentication, secure printing, easy wireless setup and device cloning. -
Configurable devices for optimized performance
The SMART MultiXpress M4370LX is unique configuration can accommodate businesses of all sizes and industries. Factory-provided modules serve as the foundation for adding various components and customizing with optional components.
- Samsung MultiXpress M4370LX - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 250000 pages
- Recommended Monthly Volume
- 10000 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 10.1"
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, cotton paper, punched paper, archive paper
- Standard Media Capacity
- 620 sheets
- Max Media Capacity
- 3240 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, Rendering Engine for Clean Page (RECP) technology, Samsung SMART UX Centre
- Power
- AC 230 V
- 63 cm x 50.6 cm x 63.6 cm
- 49 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - monochrome
- 250000 pages
- 10000 pages
- Display Diagonal Size
- 10.1"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Up to 43 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Edge Erase, margin shift
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- First Print Out Time B/W
- 8 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 98 x 148 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 620 sheets
- 3240 sheets
- 100 sheets
- 100 sheets
- ADF - 100 sheets , Paper cassette - 520 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W , Printing: up to 45 ppm (Letter A) - B/W , Copying: up to 43 ppm (A4) - B/W , Copying: up to 45 ppm (Letter A) - B/W , Scanning: up to 43 ipm - B/W , Scanning: up to 70 ipm - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Apple Bonjour, IPsec, IP filtering, MAC address filtering
- Operating System Support
- HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
- Voltage Required
- AC 230 V
- 1000 Watt
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 5 sec
- ENERGY STAR Certified
- Blue Angel Compliant
- 63 cm
- 50.6 cm
- 63.6 cm
- 49 kg
- Sound Emission
- 37 dBA (idle) / 58 dBA (operating)
