Product
Samsung MultiXpress K4250RX A3 Mono Laser Multifunction Printer
Call Your Account Manager for Pricing!
Quicklinx: B316WS00 Mfr#: SL-K4250RX/SEE
Use the intuitive Samsung SMART UX Center powered by Android. Access a range of preloaded applications and custom widgets, print fast at speeds of up to 25 ppm and boost productivity, get professional print results with high-quality output.
  • Super smart is now super simple
    A way of printing for smart and innovative businesses.
  • Touch to print, just like on a tablet
    Innovation and usability is built into the SMART MultiXpress K4250RX. The Samsung SMART UX Center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android -based devices.
  • Enjoy preloaded applications and widgets
    It's all about convenience and flow. Your favorite applications such as Copy, Scan / Send, Box, Job Status, Address Book and Help come preloaded while custom widgets provide instant access to frequently used functions.
  • Faster printing
    The SMART MultiXpress K4250RX is equipped with a 1 GHz dual-core CPU that powers printing at 25 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently.
  • Stand out with sharp, high-quality print output
    Samsung's unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out.
  • Save resources with low TCO printing
    Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 35000 standard B&W pages and drums that yield 200000 will lower your TCO and reduce waste.
Samsung MultiXpress K4250RX - multifunction printer (B/W)
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
5000 pages
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
10.1"
Original Size
A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
98 x 148 mm (min) - 297 x 432 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, thin paper, thick paper, card stock, extra heavy-weight paper, glossy paper, cotton paper, punched paper, preprinted paper, archive paper
Standard Media Capacity
1140 sheets
Max Media Capacity
2180 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, Rendering Engine for Clean Page (RECP) technology, Business Core Printing Solutions (BCPS), Samsung SMART UX Centre
56.6 cm x 61 cm x 82.9 cm
61.7 kg
Printing Technology
Laser - monochrome
100000 pages
5000 pages
Display Diagonal Size
10.1"
Display Features
Touch screen
Standard Memory
2 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy, Image Repeat, Poster Copy, Job Build
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
98 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 297 x 432 mm, 148.5 x 210 mm, 297 x 354 mm
1140 sheets
Max Media Capacity
2180 sheets
100 sheets
500 sheets
ADF - 100 sheets - A3/Ledger (297 x 432 mm) weight: 42 g/m² - 163 g/m² , 2 x paper cassette - 520 sheets size: 98 x 148 mm - 297 x 354 mm weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - 297 x 432 mm weight: 60 g/m² - 176 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 25 ppm (Letter A) - B/W , Scanning: up to 45 ipm - B/W , Scanning: up to 18 ipm - B/W duplex , Scanning: up to 45 ipm - colour , Scanning: up to 18 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, MS Windows Server 2012, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Android, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
1.3 kW
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
6.2 sec
56.6 cm
61 cm
82.9 cm
61.7 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
