Samsung toner cartridges are specifically designed to use with your Samsung printer. You'll get first-rate print quality with crisp, vibrant output from the first page to the last. They're easy to install, affordable and deliver, sharp, professional results every time you print.
This toner uses Samsung's polymerized toner, which is made of smaller, more uniform toner particles than traditional toner, and produces sharper and crisper images. Higher wax content protects printouts against folds and smudges better. And a lower fusing temperature helps reduce power consumption.
- Samsung MLT-D309S - black - original - toner cartridge
- Product Type
- Toner cartridge
- Printing Technology
- Laser
- Printing Colour
- Black
- Yield
- Up to 10000 pages
- Compatible with
- ML-5510N, 5510ND, 5515ND, 6510ND, 6512ND, 6515ND
Consumable
- Consumable Type
- Toner cartridge
- Laser
- Black
- Included Qty
- 1-pack
- Yield
- Up to 10000 pages
- RoHS, WEEE, MSDS
- Compatible with
- Samsung ML-5510N, 5510ND, 5515ND, 6510ND, 6512ND, 6515ND
