Samsung MLT-D205L - Toner cartridge - high capacity - 1 x black - 5000 pages
Quicklinx: 7PRHWS00 Mfr#: MLT-D205L/ELS
Samsung toner cartridge is specifically designed to use with your Samsung printer. You'll get first-rate print quality with crisp, vibrant output from the first page to the last. It is easy to install, affordable and deliver, sharp, professional results every time you print.
  • NO NOIS
    Imagine a printer that operates quietly and allows you to concentrate on other important tasks while it prints. The NO-NOIS engine design means the toner is stored in a fixed cartridge mechanism, eliminating noise and vibration. It also simplifies toner changes - there are no heavy toners to change, just small, easy-to-access toner bottles.
  • Genuine quality
    Enjoy consistent print results. With Samsung supplies you're virtually guaranteed high quality pages without any defects.
  • Security label
    Samsung supplies include a color-changing security label that proves they are genuine products. When the label is tilted, the color changes from clear to cyan. Plus, the embossed characters change between red gold and blue when seen from different angles. You can also verify its originality by feeling its texture.
  • Easy-to-change toner
    No mess. No fuss. Samsung printer cartridges are easy to replace so you can get back to work. Simply follow three easy steps: open the front cabinet, change the cartridge, and close the cabinet. That's all there is to it!
  • Standardized cartridge
    Samsung LaserJet cartridge has been tested to meet ISO (International Organization for Standardization) standards, which makes it easy to compare toner yields from different manufacturers. With Samsung toner cartridge, you can be confident that you're making an informed buying decision.
  • Automatic toner monitoring system
    Never get stuck on empty again. When toner is running low, the automatic toner monitoring system conveniently notifies you.
Samsung MLT-D205L - high capacity - black - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Cartridge Yield
High capacity
Yield
Up to 5000 pages at 5% coverage
Compatible with
ML-3310D, 3310ND, 3312ND, 3710D, 3710ND, 3712DW, 3712ND; SCX-4833FD, 4833FR, 4835FD, 4835FR, 5637FR, 5639FR, 5737FW, 5739FW
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Included Qty
1-pack
Cartridge Yield
High capacity
Yield
Compatible with
Samsung ML-3310D, 3310ND, 3312ND, 3710D, 3710ND, 3712DW, 3712ND , Samsung SCX-4833FD, 4833FR, 4835FD, 4835FR, 5637FR, 5639FR, 5737FW, 5739FW
