Samsung mono printer is designed for the modern office, combining flexible features that deliver speed, security, low cost of ownership and of course exceptional print quality.
Powerful printing
Powerful dual core processors with Samsung's state-of-the-art System-On-Chip technology combined with a Gigabit LAN support enables large documents from multiple users to be received, processed and printed quickly. -
Polymerized printing technology
Produce sharper images and lines, thanks to the unique polymerized toner particles. The format of the toner enables the printer to transfer the print onto the paper in a thinner layer, reducing waste and requiring a lower fusing temperature. -
Impressive paper handling
The devices offers a wide range of paper handling capabilities, including duplex as standard, higher than average paper capacity, heavier media compatibility and full range of finishing options on the high volume printing devices. -
State-of-the-art user interface
Easy-to-use LCD control panel and numeric keypad facilitates effective operation of the device to help promote secure and confidential printing.
- Samsung ML-6515ND - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 34.8 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- Samsung 600 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, EPSON, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper
- Total Media Capacity
- 620 sheets
- Media Handling
- 100-sheet multipurpose tray, 520-sheet input tray
- Monthly Duty Cycle (max)
- 275000 impressions
- Networking
- Print server
- System Requirements
- UNIX, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.4 - 10.8
- 46.4 cm x 54 cm x 42 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.8 sec
- Media Handling
- Processor
- Samsung 600 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 620 sheets
- Media Feeders
- 1 x automatic - 520 sheets , 1 x manual - 100 sheets
- Max Media Capacity
- 3660 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages
- Power Device
- Power supply
- 900 Watt
- Power Consumption Stand by
- 120 Watt
- Power Consumption Sleep
- 3.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 58 dBA
- 46.4 cm
- 54 cm
- 42 cm
- 34.8 kg
