An increasing number of organizations are using large format displays (LFDs) to display their business content and to differentiate their organization from competitors. Companies need displays that offer excellent image resolution but are lighter weight and take up minimal space. The Samsung MEC series LED LFD delivers superior LED technology in a slim display without increasing energy costs. Equipped with Samsung's powerful and exclusive SSSP technology and integrated display solution, MagicInfo Premium S player, the Samsung MEC series can deliver multiple types of content seamlessly. Watch your display management productivity go up as your total cost of ownership goes down with this all-in-one display.
Easy content creation
Easily create multimedia and interactive content with pre-made templates and customize compelling messages using drag and drop and the intuitive user interface. -
Easy and efficient content deployment
Play content on multiple displays from a central PC, directly from internal storage or USB drive through simple Plug and Play. -
An integrated solution to provide a digital signage experience
The Samsung Smart Signage Platform (SSSP) is embedded within Samsung displays, providing the power of a dual-core CPU and a combination of media player and integrated display solution, MagicInfo Premium S player. The solution eliminates the need for additional PC modules while reducing installation and maintenance issues. Using the included MagicInfo Premium S player, businesses can create, schedule, and deploy content effortlessly. Multiple types of content can be streamed simultaneously and continuously courtesy of the dual-core CPU and 8 GB of storage, and a high performance video processor integrated on a single chip. Save more by paying less for a display integrated with a media player and premium management solution. -
Project large-scale images with less energy consumption
The Samsung MEC series is economical and gentle on the environment. The MEC Series' edge-type LED features LED lamps located on the sides of the panel. The lamps emit light on the display sides, resulting in a much thinner screen that requires fewer lamps than conventional panels. With fewer LED lamps, power consumption and heat emission are reduced and a slim, lightweight design can be achieved. With these improvements, a more enjoyable environment can be created for viewers in close proximity to the displays. -
Enhance readability with extraordinary picture quality
The Samsung MEC series delivers high-quality images without the distortion, blur or glare inherent in traditional projectors to provide productive, distraction-free presentations. An ultra-clear panel provides sharper, more detailed images and enhanced picture quality. The panel also reduces light scatter and reflection to enhance readability. An enhanced contrast ratio and high brightness support more attractive, vibrant displays with detailed images. -
Greater display flexibility with image rotation
The MEC series offers Image Rotation feature, enabling image orientation rotation from portrait to landscape for greater display flexibility.
- Samsung ME40C 40" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with built-in PC
- Diagonal Class
- 40"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 110 Watt
- Power Consumption (On mode)
- 90 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 131 kWh
- Dimensions (WxDxH) - without stand
- 92.21 cm x 2.99 cm x 53.94 cm
- 10.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class C
- 110 Watt
- 90 W
- 131 kWh
- Diagonal Class
- 40"
- Commercial Use
- Combined With
- Built-in PC
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 92.21 cm
- 2.99 cm
- 53.94 cm
- 10.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Dynamic Contrast Ratio
- 5000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.15375 x 0.46125mm
- Response Time
- 8 ms
- Button lock
- Pivot, Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo Lite, Smart Scheduling
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, AVC, H.264, VC-1
- Supported Audio Formats
- AC3, DTS
- Supported Pictures Formats
- JPG, PNG
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 ( 1 GHz ) 4 GB
- 4 GB
- Operating System
- Linux
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 2 x HDMI input , Composite video / component video input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
- Cables Included
- VGA cable
- EN55022, FCC Part 15 B
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 102 cm
- Depth (Shipping)
- 13 cm
- Height (Shipping)
- 61.6 cm
- Weight (Shipping)
- 12.6 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
