Lower TCO
The Energy Start 5.0 approved, LED technology consumes an average of 40% less power, for lower total cost of ownership. LED technology also contains no mercury, which is easier on the environment. -
Ultra-slim chassis & thin bezel
The ultra-slim chassis 29.9mm (1.18") and a thin bezel 15.1mm (0.59") design of the Samsung LED LCD commercial displays provide a new era of sophistication and efficiency. The ME-series have an ultra-slim style that effortlessly draws your eyes to the screen and its ultra-light design enables easier installation and maintenance. It's a high-impact display that saves space with style. -
Create impact with great features
Create impact with great features, maximize your impact with a great features. Your message will be heard loud and clear with built-in speakers. The display features RS232C and RJ45 ports that makes display control simple. And a built-in digital TV tuner, to display television broadcasts in a display that is suited for rigorous commercial environments.
- Samsung ME40B 40" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 40"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Sound Effects
- SRS TruSurround HD, SRS TruDialog
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 102 Watt
- Dimensions (WxDxH) - without stand
- 92.12 cm x 2.99 cm x 53.61 cm
- 10.5 kg
- 3-year warranty
- Product Type
- 102 Watt
- Diagonal Class
- 40"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 92.12 cm
- 2.99 cm
- 53.61 cm
- 10.5 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 100000:1
- Brightness
- 350 cd/m²
- Colour Gamut
- 72%
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.46125 x 0.15375mm
- Response Time
- 8 ms
- V-Sync Rate at Max Res.
- 60 Hz
- Max V-Sync Rate
- 75 Hz
- Max H-Sync Rate
- 81 kHz
- Multiple Display Control (MDC), MagicInfo Lite, LED BLU
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, DivX, ASF, AVI, MKV, VOB, TS, AVC, H.264, 3GPP, VC-1
- Supported Audio Formats
- MP3, WMA, AC3, AAC, LPCM, HE-AAC, ADPCM
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A8 ( 800 MHz ) 4 GB
- 4 GB
- Operating System
- Linux
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Surround Mode
- Sound Effects
- Equaliser
- Yes (5-band)
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Bass & treble control, balance control
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI input - rear , Composite video / component video input - rear , Audio line-in - rear , DVI-D input - rear , VGA input - rear , Audio line-out - rear , Serial input - rear , Multiple Display Control - rear , USB - rear , DisplayPort - rear , Serial output - rear , DVI-D output - rear , IR Blaster - rear , Audio line-in - rear
- Cables Included
- VGA cable
- EN55022, FCC Part 15 B, EN 60065, IEC 60065, EMC
- Power Device
- Power supply - internal
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
- Limited warranty - parts and labour - 3 years
- Width (Shipping)
- 103.6 cm
- Depth (Shipping)
- 15 cm
- Height (Shipping)
- 63.3 cm
- Weight (Shipping)
- 12.9 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
