Samsung ME40B 40" LED 1920X1080 VGA DVI RJ45 Speakers Black
Quicklinx: 8BCRWS00 Mfr#: LH40MEBPLGC/EN
  • 1080p
  • Lower TCO
    The Energy Start 5.0 approved, LED technology consumes an average of 40% less power, for lower total cost of ownership. LED technology also contains no mercury, which is easier on the environment.
  • Ultra-slim chassis & thin bezel
    The ultra-slim chassis 29.9mm (1.18") and a thin bezel 15.1mm (0.59") design of the Samsung LED LCD commercial displays provide a new era of sophistication and efficiency. The ME-series have an ultra-slim style that effortlessly draws your eyes to the screen and its ultra-light design enables easier installation and maintenance. It's a high-impact display that saves space with style.
  • Create impact with great features
    Create impact with great features, maximize your impact with a great features. Your message will be heard loud and clear with built-in speakers. The display features RS232C and RJ45 ports that makes display control simple. And a built-in digital TV tuner, to display television broadcasts in a display that is suited for rigorous commercial environments.
Samsung ME40B 40" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Sound Effects
SRS TruSurround HD, SRS TruDialog
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
Remote control
Voltage
102 Watt
92.12 cm x 2.99 cm x 53.61 cm
10.5 kg
3-year warranty
102 Watt
Diagonal Class
40"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
92.12 cm
2.99 cm
53.61 cm
10.5 kg
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
100000:1
Brightness
350 cd/m²
Colour Gamut
72%
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.46125 x 0.15375mm
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
75 Hz
Max H-Sync Rate
81 kHz
Multiple Display Control (MDC), MagicInfo Lite, LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, DivX, ASF, AVI, MKV, VOB, TS, AVC, H.264, 3GPP, VC-1
Supported Audio Formats
MP3, WMA, AC3, AAC, LPCM, HE-AAC, ADPCM
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
1
Configuration
ARM Cortex-A8 ( 800 MHz ) 4 GB
4 GB
Operating System
Linux
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Surround Mode
Sound Effects
Equaliser
Yes (5-band)
Speaker System
2 speakers
Output Power / Total
20 Watt
Bass & treble control, balance control
Speakers
2 x main channel speaker - 10 Watt
Connector Type
HDMI input - rear , Composite video / component video input - rear , Audio line-in - rear , DVI-D input - rear , VGA input - rear , Audio line-out - rear , Serial input - rear , Multiple Display Control - rear , USB - rear , DisplayPort - rear , Serial output - rear , DVI-D output - rear , IR Blaster - rear , Audio line-in - rear
VGA cable
EN55022, FCC Part 15 B, EN 60065, IEC 60065, EMC
Power supply - internal
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - parts and labour - 3 years
Width (Shipping)
103.6 cm
Depth (Shipping)
15 cm
Height (Shipping)
63.3 cm
Weight (Shipping)
12.9 kg
10 - 80% (non-condensing)
