Samsung MD65C 65" 1920x1080 6.5ms DVI-D HDMI DisplayPort LED Large Format Display
Quicklinx: 8YL0WS00 Mfr#: LH65MDCPLGC/EN
  • 1080p
Samsung MD65C is a large sized display with superb picture quality and interactivity for impactful information delivery. With the versatility to become a projector, interactive touch screen or whiteboard, the 65-inch large sized displays will help you effectively share your information with the audience anywhere: in the classroom, business conferences, and any place where you want to engage the audience.
MD65C displays are an exceptional choice over projectors and screens for delivering content in a meeting room. Slim and light with narrow bezels, these digital signages are easy to handle and install. Unlike projected images in a darkened room, digital signage presentations retain picture quality with broad color ratios, deep blacks and sharp images, even in bright light. Content shown on MD65C displays has virtually no distortion. Images aren't blurred when the screen is touched. The presenter isn't dazzled by light from a projector, nor does the presenter throw a shadow on the screen. The reduced light scatter and reduced reflection make the content easier to read, increasing audience concentration. With all of these features, MD65C displays are the perfect alternatives for a projector or a screen, and what's more, your presentation area is free from machinery and cables. Also, with no bulbs to replace and less overall maintenance than a projector, MD65C displays have a longer, easier-to-maintain life span.
Samsung MD65C MD-C Series - 65" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
Settings Cloning Capability
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
Remote control
Voltage
Energy Class
Class A
253 Watt
Power Consumption (On mode)
132 W
Energy Consumption per Year
193 kWh
146.74 cm x 5.62 cm x 84.8 cm
26.8 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
253 Watt
132 W
193 kWh
Diagonal Class
65"
Commercial Use
Combined With
Built-in PC
Series
MD-C Series
Video Processor
Dual-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, light sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
146.74 cm
5.62 cm
84.8 cm
26.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.248 x 0.744mm
Response Time
6.5 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo Lite, Smart Scheduling, MagicInfo Premium-S, MagicInfo Videowall-S
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
USB Port
Configuration
ARM Cortex-A9 ( 1 GHz ) - 1 GB DDR3 - 4 GB
4 GB
Operating System
Linux
Remote Control
Remote control
Network & Internet Multimedia
Wi-Fi
Connect & Share
Intel Wireless Display 2.0 (WiDi 2.0)
Connector Type
VGA input , DVI-D input , DisplayPort input , 2 x HDMI input , Composite video / component video input , Audio line-in , RGB output , Audio line-out , Serial input , Serial output , Remote control
VGA cable
Plug and Play, TUV, VCCI, C-Tick, BSMI, cUL, DDC-2B, EN 60950, EN55022, IEC 60950, EN55024, UL 60950, CISPR 22, CB, CCC, EK, AS/NZS 3548, KCC, BSMI CNS 13438, FCC Part 15 B Class A, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years - on-site
Width (Shipping)
162.5 cm
Depth (Shipping)
23.7 cm
Height (Shipping)
99.5 cm
Weight (Shipping)
39.1 kg
