Samsung MD65C is a large sized display with superb picture quality and interactivity for impactful information delivery. With the versatility to become a projector, interactive touch screen or whiteboard, the 65-inch large sized displays will help you effectively share your information with the audience anywhere: in the classroom, business conferences, and any place where you want to engage the audience.
MD65C displays are an exceptional choice over projectors and screens for delivering content in a meeting room. Slim and light with narrow bezels, these digital signages are easy to handle and install. Unlike projected images in a darkened room, digital signage presentations retain picture quality with broad color ratios, deep blacks and sharp images, even in bright light. Content shown on MD65C displays has virtually no distortion. Images aren't blurred when the screen is touched. The presenter isn't dazzled by light from a projector, nor does the presenter throw a shadow on the screen. The reduced light scatter and reduced reflection make the content easier to read, increasing audience concentration. With all of these features, MD65C displays are the perfect alternatives for a projector or a screen, and what's more, your presentation area is free from machinery and cables. Also, with no bulbs to replace and less overall maintenance than a projector, MD65C displays have a longer, easier-to-maintain life span.
- Samsung MD65C MD-C Series - 65" LED display
- Product Type
- LED-backlit LCD flat panel display with built-in PC
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Wall Components Qty
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
- Settings Cloning Capability
- Storage Drive Capacity
- 4 GB
- USB
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 253 Watt
- Power Consumption (On mode)
- 132 W
- Energy Consumption per Year
- 193 kWh
- Dimensions (WxDxH) - without stand
- 146.74 cm x 5.62 cm x 84.8 cm
- 26.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
- Product Type
- Energy Class
- Class A
- 253 Watt
- 132 W
- 193 kWh
- Diagonal Class
- 65"
- Commercial Use
- Combined with
- Built-in PC
- Series
- MD-C Series
- TV Tuner
- No tuner
- Sensors
- Temperature sensor, light sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- 100
- Dimensions
- Without stand
- 146.74 cm
- 5.62 cm
- 84.8 cm
- 26.8 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Dynamic Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.248 x 0.744mm
- Response Time
- 6.5 ms
- Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo Lite, Smart Scheduling, Dual-Core processor, MagicInfo Premium-S, MagicInfo Videowall-S
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, AVC, H.264, VC-1
- Supported Audio Formats
- AC3, DTS
- Supported Pictures Formats
- JPG, PNG
- USB Port
- PC Configuration
- ARM Cortex-A9 / 1 GHz / 1 GB DDR3
- 4 GB
- Operating System
- Linux
Remote Control
- Standard remote
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connect & Share
- Intel Wireless Display 2.0 (WiDi 2.0)
- Connector Type
- VGA input , DVI-D input , DisplayPort input , 2 x HDMI input , Composite video / component video input , Audio line-in , RGB output , Audio line-out , Serial input , Serial output , Remote control
- Cables Included
- VGA cable
- Plug and Play, TUV, VCCI, C-Tick, BSMI, cUL, DDC-2B, EN 60950, EN55022, IEC 60950, EN55024, UL 60950, CISPR 22, CB, CCC, EK, AS/NZS 3548, KCC, BSMI CNS 13438, FCC Part 15 B Class A, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years - on-site
- Width (Shipping)
- 162.5 cm
- Depth (Shipping)
- 23.7 cm
- Height (Shipping)
- 99.5 cm
- Weight (Shipping)
- 39.1 kg
