Give your devices the powerful charging support they deserve. The Wall Charger for Super Fast Charging (25W) provides Super Fast Charging at up to 25W for capable devices.
Use the Wall Charger with an official Samsung Type C to Type C charging cable for optimum results.
Manufacturer warranty - 12 Months
Super Fast Charging to stay live
Give your devices the powerful charging support they deserve. The 25W PD Travel Adapter provides Super Fast Charging at up to 25W for capable devices. Use the Travel Adapter with an official Samsung Type C to Type C Charging Cable for optimum results. -
Get the ideal charge every time
The Travel Adapter not only quickly powers the fastest charging devices, but plays well with other models too. So for standard PD 3.0 compatible devices you'll get a max 25W charge, while others charge at speeds they can handle.
- Samsung EP-TA800 power adapter - 24 pin USB-C - 25 Watt
- Product Type
- Power adapter
- Designed For
- Mobile phone
- 5.025 cm x 2.721 cm x 6.875 cm
- 63 g
- Black
- Output Connector Type
- 24 pin USB-C
- Voltage Required
- AC 100-240 V
- Voltage Provided
- 3.3 - 5.9 / 3.3 - 11 / 5 / 9 V
- Max Electric Current
- 3 A
- Fast Charge Technology
- Samsung Super Fast Charge, Power Delivery 3.0
- Power Provided
- 25 Watt
- Designed For
- Galaxy A20, A20e, A20s, A30, A30s, A40, A5, A50, A50s, A60, A7, A70, A70s, A8, A8+, A80, A8s, A9, A90, A90 5G, C9, Fold, Fold 5G, M20, M30, M30s, M40, Note10, Note10+, Note10+ 5G, Note8, Note9, S10, S10 5G, S10+, S10e, S20, S20 5G, S20+, S20+ 5G, S8, S8+, S9, S9+, Xcover 4s, Z Flip, Z Flip 5G
- Product Type
- Power adapter
- Designed For
- Mobile phone
- 5.025 cm
- 2.721 cm
- 6.875 cm
- 63 g
- Enclosure Colour
- Black
- Voltage Required
- AC 100-240 V
- Input Connectors
- Power
- Input Connectors Qty
- 1
- Voltage Provided
- Output connectors
- 24 pin USB-C
- Power Provided
- 25 Watt
- 3 A
- USB Power Delivery 3.0
- Designed For
- Samsung Galaxy A20, A20e, A20s, A30, A30s, A40, A5 (2017), A50, A50s, A60, A7 (2017), A70, A70s, A8 Star, A8+ (2018), A80, A8s, A9 (2018), A90, A90 5G, C9 Pro, Fold, Fold 5G, M20, M30, M30s, M40, Note10, Note10 Lite, Note10+, Note10+ 5G, Note8, Note9, S10, S10 5G, S10+, S10e, S20, S20 5G, S20 5G UW, S20 FE, S20 FE 5G, S20 FE 5G UW, S20 Ultra, S20 Ultra 5G, S20+, S20+ 5G, S8, S8+, S9, S9+, Xcover 4s, Z Flip, Z Flip 5G
