Samsung M4020ND Mono Laser Printer
Quicklinx: 9155WS00 Mfr#: SL-M4020ND/SEE
The robust ProXpress M4020ND features print speeds of up to 42 ppm. Powered by a Cortex-A5 core processor and 256 MB of memory, it delivers unsurpassed performance for business applications. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency.
ReCP technology improves the readability of printed documents by enhancing thin lines and sharpening the edges of fine text. The ProXpress M4020ND delivers sharp, solid prints with effective output print resolutions of up to 1,200 x 1,200 dpi.
  • High speed printing
  • Higher-quality print output
  • Robust paper handling
    The printers' multipurpose tray supports media of up to 58 lbs. weight, which offers more printing choices for professional documents. Labels, cards, covers and envelopes can be printed using the multi-purpose tray with ease. This ability virtually eliminates the time it takes to feed sheets one at a time.
  • Built-in Duplex Printing
    The ProXpress M4020ND features standard automatic duplex. Users can print on both sides of the page with ease, saving the company on costs, and reducing the impact on the environment.
  • One touch Eco button
    Businesses can lower toner and paper usage with the one touch Eco Button. The one touch Eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides), as well skipping blank pages and printing in toner save mode.
Samsung ProXpress M4020ND - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
10.18 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN
600 MHz
RAM Installed (Max)
256 MB (512 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, SPL (Samsung Printer Language), IBM ProPrinter, EPSON
Media Type
Envelopes, transparencies, labels, plain paper, cards, recycled paper, cotton paper, bar code labels, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet paper cassette, 50-sheet bypass tray
Monthly Duty Cycle (max)
100000 pages
UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8
36.6 cm x 26.25 cm x 36.56 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Language Simulation
Media Handling
600 MHz
RAM
RAM Installed (Max)
256 MB / 512 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
820 sheets
Output Trays Capacity
150 sheets
Duty Cycle
100000 pages
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 3000 pages
Power supply - internal
700 Watt
Power Consumption Stand by
10 Watt
Power Consumption Sleep
1.1 Watt
Sound Emission (Idle)
26 dBA
Sound Emission (Operating)
57 dBA
36.6 cm
26.25 cm
36.56 cm
10.18 kg
