Samsung M3370FD Mono Laser Printer
Quicklinx: 8T27WS00 Mfr#: SL-M3370FD/SEE
High productivity and cost-efficiency in a versatile MFP
Create professional documents more quickly
  • High speed printing of up to 38 ppm1 (pages per minute).1 Higher-quality print output
  • ReCP (Rendering engine for Clean Page) technology for sharp text and clear images.
  • 1,200 x 1,200 effective dpi (dots per inch) resolution.
  • Additional printing choices for professional documents
  • A multipurpose tray that handles a wide range of media, up to 220 gsm (grams per square meter), suchas labels, cardstock and envelopes.
Reduce operating expenses with economical features and solutions
  • Professional eco solution
  • Easy Eco Driver enables users to set options to remove unnecessary text or images and also change the layout such as N-up printing without changing the original documents prior to print
  • One Touch Eco Button automatically activates 2-up (two pages on one side of the paper) and duplex printing, toner-save mode and the option to skip blank pages.
More toner options, more choices for cost reduction
  • Diverse toner options from 3,000 to 10,000 page yields that meet every businesses' needs for reducing cost per page.
  • An integrated toner system contains the imaging unit and toner cartridge in one convenient package. This integrated toner system is the preferred choice for businesses with a heavier printing volume who requirea lower CPP and easier maintenance.
Central print usage control to save more resources
  • Samsung SyncThruTM Admin solution enables management to assign users to specific devices, and assign predetermined quotas for the number of printed pages or copies by user.
Improve productivity with versatile features from multifunction to security
4-in-1 multifunctional (print, copy, scan and fax) capabilities and built-in duplex printing provide the versatility that businesses need to stay competitive.Mobile printing, easier than ever.
  • Convenient mobile print, scan and fax with powerful compatibility, optimized for various business environments.
  • Enterprise-level document security offers greater control of user, document and network access.
Streamline printing with ease- of-use design
  • Easy Printer Manager for smooth print operation from toner and job accounting to device settings.
  • Easy Document Creator to create and share digital documents in multiple formats with minimal effort.
  • Easy secure printing with a built-in numeric key pad.
  • 4-in1 multifunction with automatic duplex
    With 4-in-1 capability including print, copy, scan and fax and built-in duplex printing you can be sure the ProXpress M3370FD provides your business the versatility you need to stay competitive.
  • Higher-quality print output
    ReCP technology improves the readability of printed documents by enhancing thin lines and sharpening the edges of fine text. Small text that typically may not scan completely is sharpened through edge resolution enhancement, and half-tone patterns are removed to produce smooth images without visual artifacts. The ProXpress M3370FD delivers sharp, solid prints with effective output print resolutions of up to 1,200 x 1,200 dpi.
  • One touch eco button
    Businesses can lower toner and paper usage with the one touch eco button. The one touch eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides), as well skipping blank pages and printing in toner save mode. The default eco settings can be adjusted using easy printer manager, and administrators can even enforce some or all of these rules in order to save your business money.
  • Central print usage control to save more resources
    Central print usage control, activated through the SyncThru Admin Job Accounting feature, enables managers to assign users to specific printers, as well as assigning individual users or workgroups quotas. Tight usage controls as well as automatic notifications help business control costs and drive down spending.
  • More laser toner cartridge options, more choices for cost reduction
    The ProXpress M33370FD employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also offers both a standard-yield laser toner cartridges that typically yield 3,000 standard pages and a high yield laser toner cartridges that can yield up to 5,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs.
  • Easy printer manager
    The easy printer manager helps companies remotely control settings, such as the one touch eco button, and easily access notifications and device status from one convenient location. Multiple devices can be monitored and managed using the easy printer manager. Businesses can also monitor printer status, such as error messages, including paper empty, toner empty and paper jam alerts.
    The ProXpress M3370FD features easy secure printing with a built-in numeric keypad, which allows users to protect personal or confidential documents. Users can select a secure print job through their driver, or administrators can force all jobs to require authentication. Once a secure print job is sent, it will only release when the user walks up and types in their PIN at the printer. This feature can protect sensitive documents from prying eyes, or reduce the number of wasted prints if a user decides not to pick up their print job. And best of all, this feature is included at no additional cost.
Samsung ProXpress M3370FD - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 impressions
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, recycled paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Max Media Capacity
771 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to e-mail, scan to folder, scan to network
41.46 cm x 42.06 cm x 44.91 cm
15.15 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 impressions
Display
4 lines
USB 2.0, LAN
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Up to 33 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1, ID Card Copy, collation copy
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, IBM Proprinter, SPL, PDF, EPSON
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Broadcast Transmission
209 stations
Delayed Transmission
Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
250 sheets
Max Media Capacity
771 sheets
1 sheet
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 33 ppm (A4) - B/W , Printing: up to 35 ppm (Letter A) - B/W , Copying: up to 33 ppm (A4) - B/W , Copying: up to 35 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
700 Watt
Power Consumption Standby
10 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages
ISO/IEC 19752
41.46 cm
42.06 cm
44.91 cm
15.15 kg
Sound Emission
26 dBA (idle) / 57 dBA (operating)
