High productivity and cost-efficiency in a versatile MFP
Create professional documents more quickly
- High speed printing of up to 38 ppm1 (pages per minute).1 Higher-quality print output
- ReCP (Rendering engine for Clean Page) technology for sharp text and clear images.
- 1,200 x 1,200 effective dpi (dots per inch) resolution.
- Additional printing choices for professional documents
- A multipurpose tray that handles a wide range of media, up to 220 gsm (grams per square meter), suchas labels, cardstock and envelopes.
Reduce operating expenses with economical features and solutions
- Professional eco solution
- Easy Eco Driver enables users to set options to remove unnecessary text or images and also change the layout such as N-up printing without changing the original documents prior to print
- One Touch Eco Button automatically activates 2-up (two pages on one side of the paper) and duplex printing, toner-save mode and the option to skip blank pages.
More toner options, more choices for cost reduction
- Diverse toner options from 3,000 to 10,000 page yields that meet every businesses' needs for reducing cost per page.
- An integrated toner system contains the imaging unit and toner cartridge in one convenient package. This integrated toner system is the preferred choice for businesses with a heavier printing volume who requirea lower CPP and easier maintenance.
Central print usage control to save more resources
- Samsung SyncThruTM Admin solution enables management to assign users to specific devices, and assign predetermined quotas for the number of printed pages or copies by user.
Improve productivity with versatile features from multifunction to security
4-in-1 multifunctional (print, copy, scan and fax) capabilities and built-in duplex printing provide the versatility that businesses need to stay competitive.Mobile printing, easier than ever.
- Convenient mobile print, scan and fax with powerful compatibility, optimized for various business environments.
- Enterprise-level document security offers greater control of user, document and network access.
Streamline printing with ease- of-use design
- Easy Printer Manager for smooth print operation from toner and job accounting to device settings.
- Easy Document Creator to create and share digital documents in multiple formats with minimal effort.
- Easy secure printing with a built-in numeric key pad.
4-in1 multifunction with automatic duplex
With 4-in-1 capability including print, copy, scan and fax and built-in duplex printing you can be sure the ProXpress M3370FD provides your business the versatility you need to stay competitive. -
ReCP technology improves the readability of printed documents by enhancing thin lines and sharpening the edges of fine text. Small text that typically may not scan completely is sharpened through edge resolution enhancement, and half-tone patterns are removed to produce smooth images without visual artifacts. The ProXpress M3370FD delivers sharp, solid prints with effective output print resolutions of up to 1,200 x 1,200 dpi. -
One touch eco button
Businesses can lower toner and paper usage with the one touch eco button. The one touch eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides), as well skipping blank pages and printing in toner save mode. The default eco settings can be adjusted using easy printer manager, and administrators can even enforce some or all of these rules in order to save your business money. -
Central print usage control, activated through the SyncThru Admin Job Accounting feature, enables managers to assign users to specific printers, as well as assigning individual users or workgroups quotas. Tight usage controls as well as automatic notifications help business control costs and drive down spending. -
More laser toner cartridge options, more choices for cost reduction
The ProXpress M33370FD employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also offers both a standard-yield laser toner cartridges that typically yield 3,000 standard pages and a high yield laser toner cartridges that can yield up to 5,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs. -
Easy printer manager
The easy printer manager helps companies remotely control settings, such as the one touch eco button, and easily access notifications and device status from one convenient location. Multiple devices can be monitored and managed using the easy printer manager. Businesses can also monitor printer status, such as error messages, including paper empty, toner empty and paper jam alerts. -
The ProXpress M3370FD features easy secure printing with a built-in numeric keypad, which allows users to protect personal or confidential documents. Users can select a secure print job through their driver, or administrators can force all jobs to require authentication. Once a secure print job is sent, it will only release when the user walks up and types in their PIN at the printer. This feature can protect sensitive documents from prying eyes, or reduce the number of wasted prints if a user decides not to pick up their print job. And best of all, this feature is included at no additional cost.
- Samsung ProXpress M3370FD - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 impressions
- Max Copying Speed
- Up to 33 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 33 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, recycled paper, thin paper, thick paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 771 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Scan to e-mail, scan to folder, scan to network
- 41.46 cm x 42.06 cm x 44.91 cm
- 15.15 kg
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 impressions
- Display
- 4 lines
- Interface
- USB 2.0, LAN
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Up to 33 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, collation copy
Printing
- Up to 33 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, IBM Proprinter, SPL, PDF, EPSON
- First Print Out Time B/W
- 6.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 209 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- 250 sheets
- 771 sheets
- 1 sheet
- 150 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 33 ppm (A4) - B/W , Printing: up to 35 ppm (Letter A) - B/W , Copying: up to 33 ppm (A4) - B/W , Copying: up to 35 ppm (Letter A) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
- 700 Watt
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- ISO/IEC 19752
- 41.46 cm
- 42.06 cm
- 44.91 cm
- 15.15 kg
- Sound Emission
- 26 dBA (idle) / 57 dBA (operating)
