Samsung LH40EDDPLGC 40" 1920x1080 DVI HDMI LED Large Format Display
Quicklinx: BK05WS00 Mfr#: LH40EDDPLGC/EN
  • 1080p
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED40D ED-D Series - 40" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote control
Voltage
Energy Class
Class B
110 Watt
Power Consumption (On mode)
85 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
124 kWh
92.54 cm x 9.36 cm x 54.1 cm
9.3 kg
Energy Class
Class B
110 Watt
85 W
124 kWh
Diagonal Class
40"
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
92.54 cm
9.36 cm
54.1 cm
9.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Colour Depth
Up to 1.07 billion colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
100.5 cm
Depth (Shipping)
15.1 cm
Height (Shipping)
61.5 cm
Weight (Shipping)
11.4 kg
