The SDC-7310DC is an indoor security dome camera. It comes equipped with LED infrared lamps to give it a max range of 8m during night time conditions. The camera also records at a incredibly crisp 700TVL, well above the industry standards. Lastly, the SDC-7310DCN has a dome cover that can hides unwanted wiring, giving you that extra degree of security and durability.
The SDC-7310DCN is compatible with Samsung SDS-P3042, SDS-P3022, SDS-P4042. When you purchase the camera separately, it comes with the camera , wall anchors, screws, and 18m of cable.
Recording at 720 TV Lines, the Samsung SDC-7310DC white, indoor dome camera delivers at-a-glance vividness of areas you want to keep an eye on. With an IR Cut Filter and Night Vision up to 26 feet, you can depend on the SDC-7310DC to empower you with clear, vibrant images.
Rich, High Definition
The SDC-7310DC is proof that Samsung sets its sights on exceeding your visual expectations. This indoor, 960H high resolution camera produces 720 TV Lines to deliver exceptional, true-to-life video you can count on.
True Day & Night
With a large, 1/3-inch CMOS sensor, this camera allows maximum light through the lens to yield vivid colors, brighter video and stunning detail. Its IR Cut Filter produces undistorted, true-to-life colors in daylight and switches to night mode for crisp, bright images despite the darkness.
Night Vision
The SDC-7310DC is outfitted with auto-activated infrared LED lights for discreet illumination on even the darkest nights. The camera's clear, bright Night Vision allows viewing up to 26 feet.
Wide Angle Coverage
While other cameras constrict your view, Samsung's 72° Wide Angle lens expands your recording coverage without compromising quality.
Simple Installation
The indoor white dome camera comes with everything you need to install and connect to your system, including its bracket, screws, BNC connector and 60 feet of cable. The bracket is designed to hide the cable, adding both security and durability to the system.
System Compatibility
The SDC-7310DC camera is compatible with these Samsung All-In-One DVR Systems: SDS-P5122, SDS-P5082, SDS-P5101, SDS-P5100, SDS-P5080, SDS-V5080, SDE-5003, SDS-P4082, SDS-P4042, SDS-P4080, SDS-V4040, SDS-V4041, SDE-4003, SDS-P3042, SDS-S3042, SDS-P3040, SDS-V3040, SDE-3004, SDH-P5081, SDH-P5080, SDH-V5100, SDH-P4040, SDH-P4041
- Samsung Techwin SDC-7310DCP - surveillance camera - dome
- Surveillance camera - fixed - dome
- 9.3 cm x 9.3 cm x 7.8 cm
- 179 g
- Ivory
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night - 700 TVL - PAL
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 7 lux - colour , 0 lux - B&W - infrared LEDs on
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.0
- Composite video
- Cables Included
- 1 - video / power cable - 18.3 m
- Voltage
- DC 12 V
- Digital noise reduction, infrared cut filter, auto rolling shutter, 960H technology, auto gain control, auto white balance
- Environmental Parameters (operating)
- -10 °C - 50 °C; 20 - 85% relative humidity
- Form Factor
- Dome
- Wired
- 9.3 cm
- 9.3 cm
- 7.8 cm
- 179 g
Camera
- Colour - Day&Night - fixed
- Video Format
- PAL
- Horizontal Resolution (TV Lines)
- 700
- Infrared LEDs
- Infrared Distance
- 8 m
Image Sensor
- CMOS 1/3"
- Effective Pixels
- 976 x 582
Lens Construction
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.0
- Video
- Composite video
- Ports
- Composite video - BNC
- Cables Included
- 1 x video / power cable - 18.3 m
- Ivory
- Power Requirements
- DC 12 V
- Power Device
- 3 Watt
- -10 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 85%
