Your basket is empty
Samsung In / Outdoor Bullet CCTV Camera 720p HD
Quicklinx: BBYKWS00 Mfr#: SDC-8440BCP/EU
Samsung - surveillance camera
Surveillance camera - fixed - outdoor - weatherproof
6.18 cm x 14 cm x 6.18 cm
194 g
White
Wired
Camera
Colour - Day&Night - PAL
Frame Rate
25 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/3" - 1 MP
Minimum Illumination
0 lux - infrared LEDs on
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Composite video
1 - video cable - 18.3 m
Voltage
DC 12 V
Progressive scanning, 3D Noise Reduction Technology, auto rolling shutter, flickerless, auto white balance
Environmental Parameters (operating)
-10 °C - 50 °C; 0 - 90% relative humidity
Surveillance camera
Wired
6.18 cm
14 cm
6.18 cm
194 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Video Format
PAL
Video Modes
720p
Infrared LEDs
Infrared Distance
25 m
Image Sensor
1 MP CMOS 1/3"
Effective Pixels
1280 x 960
Lens Construction
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Horizontal Field of View (degree)
78
Vertical Field of View (degree)
62.5
Video
Composite video
Ports
Composite video - BNC
1 x video cable - 18.3 m
RoHS, IP66
White
Power Requirements
DC 12 V
4 Watt
-10 °C
50 °C
Relative Humidity (operating)
0 - 90%
