Samsung HW-T400 All-in-One Soundbar (2020)
Quicklinx: FX50WS00 Mfr#: HW-T400/XU
Audio System Type: Soundbar
Surround system: 2.0 Channel
£99.99 ex VAT
£119.98 inc VAT
Bring entertainment to life with bass in a compact design
Fit more sound into your home with this all-in-one device that has built-in speakers to enhance bass performance. The speakers are specialised for low sounds like the rumble of thunder in a rainforest whilst still providing the concert of chirping birds, howler monkeys and the buzz of crickets.
Bluetooth® TV connection
Simply and seamlessly connect the soundbar to your TV wirelessly via Bluetooth and avoid a mess of cables.
USB music playback
The fun doesn't stop with movies and games. Plug in your mobile device via USB and pump up the mood with the ability to play your music without the need for complicated pairing.
Streaming music via Bluetooth
The Soundbar uses Bluetooth for easy wireless connections to other devices. Enjoy music from your mobile in top audio quality anywhere, no strings attached.
Incredible sound, no matter where you sit
Make every seat the best seat in the house, whether you are playing video games with friends or watching a movie with family. The T400 expands the optimal sound field to create wider surround sound with room-filling sound.
  • Booming bass with a built-in woofer
    Surround yourself with the deep bass you want without a separate woofer. The soundbar comes equipped with two built-in woofers and a sound duct. That means more space, and more bass for you.
  • Bluetooth TV connexion
    Simply use Bluetooth to connect the soundbar to your Samsung TV and enjoy your favourite content right away.
  • USB music playback
    This soundbar makes it easy to enjoy your own music in your own space. It comes complete with an integrated USB 2.0 port, so all you have to do is plug in a memory device with your music files and hit the play button.
  • Streaming music via Bluetooth
    The soundbar uses Bluetooth for easy wireless connexions to other devices. Enjoy music from your mobile in top audio quality anywhere, no strings attached.
  • A world of sound with one remote
    You don't need several remotes. Control key soundbar functions like power, volume, and even sound effects with the Samsung TV remote - right from your TV.
  • Enjoy wider dimensions of sound
    Surround sound expansion expands the listening area both sideways and up to emanate sound. Now you can enjoy great sound with truly immersive surround effects.
  • Enjoy sound by the NFC
    Listen to your favourite music through soundbar by placing your smartphone over the NFC.
Samsung HW-T400 - sound bar - wireless
Sound bar
Media Content Source
USB-host
Speaker Type
2-way - active
Continuous Power
40 Watt
Amplifier
Integrated
Bluetooth, NFC
Audio Formats
WAV, WMA, AAC, MP3, FLAC, LPCM
Speaker Details
Sound bar - stereo x 2 - 2-way - active
Built-in Decoders
Dolby Digital, DTS decoder, Dolby Audio
Sound Effects
Surround Sound Expansion
64.1 cm x 10.7 cm x 6.5 cm
2 kg
Sound bar
USB-host
Enclosure Colour
Speaker System
Speaker Type
2-way - active
Continuous Power
40 Watt
Maximum Sampling Rate Supported
96 kHz
Amplifier
Integrated
Sound Effects
Bluetooth, Near Field Communication (NFC)
Transmission Range
10 m
Recommended Placing
Wall-mountable / table-top
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Speaker System Details
Speaker Details
Driver Details
Sound bar: 2 x woofer driver , Sound bar: 2 x high/midrange driver
Connector Type
Digital audio input (optical) (TOS Link) , Audio line-in (mini-phone stereo 3.5 mm) , USB 2.0 (4 PIN USB Type A)
AAA battery, remote control
Power Source
Integrated power supply
15 Watt
64.1 cm
10.7 cm
6.5 cm
2 kg
Shipping Width
71.2 cm
Shipping Depth
17 cm
Shipping Height
18 cm
Shipping Weight
2.7 kg
Brand: Samsung
