Bring entertainment to life with bass in a compact design
Fit more sound into your home with this all-in-one device that has built-in speakers to enhance bass performance. The speakers are specialised for low sounds like the rumble of thunder in a rainforest whilst still providing the concert of chirping birds, howler monkeys and the buzz of crickets.
Bluetooth® TV connection
Simply and seamlessly connect the soundbar to your TV wirelessly via Bluetooth and avoid a mess of cables.
USB music playback
The fun doesn't stop with movies and games. Plug in your mobile device via USB and pump up the mood with the ability to play your music without the need for complicated pairing.
Streaming music via Bluetooth
The Soundbar uses Bluetooth for easy wireless connections to other devices. Enjoy music from your mobile in top audio quality anywhere, no strings attached.
Incredible sound, no matter where you sit
Make every seat the best seat in the house, whether you are playing video games with friends or watching a movie with family. The T400 expands the optimal sound field to create wider surround sound with room-filling sound.
Booming bass with a built-in woofer
Surround yourself with the deep bass you want without a separate woofer. The soundbar comes equipped with two built-in woofers and a sound duct. That means more space, and more bass for you. -
Bluetooth TV connexion
Simply use Bluetooth to connect the soundbar to your Samsung TV and enjoy your favourite content right away. -
USB music playback
This soundbar makes it easy to enjoy your own music in your own space. It comes complete with an integrated USB 2.0 port, so all you have to do is plug in a memory device with your music files and hit the play button. -
The soundbar uses Bluetooth for easy wireless connexions to other devices. Enjoy music from your mobile in top audio quality anywhere, no strings attached. -
A world of sound with one remote
You don't need several remotes. Control key soundbar functions like power, volume, and even sound effects with the Samsung TV remote - right from your TV. -
Enjoy wider dimensions of sound
Surround sound expansion expands the listening area both sideways and up to emanate sound. Now you can enjoy great sound with truly immersive surround effects. -
Enjoy sound by the NFC
Listen to your favourite music through soundbar by placing your smartphone over the NFC.
- Samsung HW-T400 - sound bar - wireless
- Product Type
- Sound bar
- Media Content Source
- USB-host
- Speaker Type
- 2-way - active
- Continuous Power
- 40 Watt
- Amplifier
- Integrated
- Bluetooth, NFC
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, LPCM
- Speaker Details
- Sound bar - stereo x 2 - 2-way - active
- Black
- Built-in Decoders
- Dolby Digital, DTS decoder, Dolby Audio
- Sound Effects
- Surround Sound Expansion
- 64.1 cm x 10.7 cm x 6.5 cm
- 2 kg
- Product Type
- Sound bar
- USB-host
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- 2-way - active
- Continuous Power
- 40 Watt
- Maximum Sampling Rate Supported
- 96 kHz
- Amplifier
- Integrated
- Sound Effects
- Bluetooth, Near Field Communication (NFC)
- Transmission Range
- 10 m
- Recommended Placing
- Wall-mountable / table-top
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
Speaker System Details
- Speaker Details
- Driver Details
- Sound bar: 2 x woofer driver , Sound bar: 2 x high/midrange driver
- Connector Type
- Digital audio input (optical) (TOS Link) , Audio line-in (mini-phone stereo 3.5 mm) , USB 2.0 (4 PIN USB Type A)
- Included Accessories
- AAA battery, remote control
- Power Source
- Integrated power supply
- 15 Watt
- 64.1 cm
- 10.7 cm
- 6.5 cm
- 2 kg
- Shipping Width
- 71.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 18 cm
- Shipping Weight
- 2.7 kg
