Samsung HW-MS650 Sound+ 3Ch 450W All-in-One Smart Soundbar
Quicklinx: D1L2WS00 Mfr#: HW-MS650/XU
Sound? is simply beautiful. Samsung audio technologies deliver rich, room-filling home theater sound without the need for a separate subwoofer. With a premium design and an elegant single mount option, Sound? becomes one with your TV and brings your entire home cinema experience together like never before.
Exclusive technologies blend advanced sound processing and precise speaker control to deliver just the right level of bass. Sound? delivers all-around perfect sound, no matter where you are in the room thanks to Samsung's wide range tweeter.
  • Simple sounds beautiful
  • Sound that fills the room and moves every listener
    Exclusive technologies blend advanced sound processing and precise speaker control to deliver just the right level of bass. Sound? delivers all-around perfect sound, no matter where you are in the room thanks to Samsung's Wide Range Tweeter.
  • Don't just hear it
    Distortion canceling technology predicts and cancels out distortion before it happens. Multi-speaker control increases the power and depth of bass by precisely coordinating the movement of each speaker. The result is richer, more detailed bass.Don't just hear it. Feel it.
  • Sweet anywhere you sit
    Virtually every spot is the sweet spot. Get consistently amazing sound everywhere in the room with Samsung's wide range tweeter, which covers a wide frequency range.
  • Get real, with HD audio
    Hear your music the way it was meant to be heard, with more nuance and depth. HD Audio preserves the quality and richness of the original sound through 96kHz/24 bit high resolution audio.
  • Gain control with OneRemote
    Spend less time switching between remote controls. Your 2017 Samsung TV OneRemote now manages many of the Soundbar's functions through the TV UI.
Samsung Sound+ HW-MS650 - sound bar - for home theatre - wireless
Sound bar - for home theatre
System Components
Sound bar
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Bluetooth, Wi-Fi
Audio Formats
WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC
Speaker System Details
1 x sound bar
Speaker Details
Sound bar - stereo x 2 , Sound bar - centre channel
Dark titan
Built-in Decoders
Dolby Digital, DTS decoder
106 cm x 13.1 cm x 7.8 cm
6.2 kg
Enclosure Colour
Dark titan
Speaker System
System Components
Sound bar
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Bluetooth 4.0, Wi-Fi
Built-in Decoders
Audio Formats
Speakers Included
1 x sound bar
Speaker Details
Driver Details
Sound bar: 6 x full-range driver , Sound bar: 3 x tweeter driver
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , SPDIF input (TOS Link)
Remote control, wall mount
106 cm
13.1 cm
7.8 cm
6.2 kg
