Sound? is simply beautiful. Samsung audio technologies deliver rich, room-filling home theater sound without the need for a separate subwoofer. With a premium design and an elegant single mount option, Sound? becomes one with your TV and brings your entire home cinema experience together like never before.
Exclusive technologies blend advanced sound processing and precise speaker control to deliver just the right level of bass. Sound? delivers all-around perfect sound, no matter where you are in the room thanks to Samsung's wide range tweeter.
Simple sounds beautiful
Sound? is simply beautiful. Samsung audio technologies deliver rich, room-filling home theater sound without the need for a separate subwoofer. With a premium design and an elegant single mount option, Sound? becomes one with your TV and brings your entire home cinema experience together like never before. -
Sound that fills the room and moves every listener
Exclusive technologies blend advanced sound processing and precise speaker control to deliver just the right level of bass. Sound? delivers all-around perfect sound, no matter where you are in the room thanks to Samsung's Wide Range Tweeter. -
Don't just hear it
Distortion canceling technology predicts and cancels out distortion before it happens. Multi-speaker control increases the power and depth of bass by precisely coordinating the movement of each speaker. The result is richer, more detailed bass.Don't just hear it. Feel it. -
Sweet anywhere you sit
Virtually every spot is the sweet spot. Get consistently amazing sound everywhere in the room with Samsung's wide range tweeter, which covers a wide frequency range. -
Get real, with HD audio
Hear your music the way it was meant to be heard, with more nuance and depth. HD Audio preserves the quality and richness of the original sound through 96kHz/24 bit high resolution audio. -
Gain control with OneRemote
Spend less time switching between remote controls. Your 2017 Samsung TV OneRemote now manages many of the Soundbar's functions through the TV UI.
- Samsung Sound+ HW-MS650 - sound bar - for home theatre - wireless
- Product Type
- Sound bar - for home theatre
- System Components
- Sound bar
- Speaker Type
- Active
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Audio Formats
- WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC
- Speaker System Details
- 1 x sound bar
- Speaker Details
- Sound bar - stereo x 2 , Sound bar - centre channel
- Dark titan
- Built-in Decoders
- Dolby Digital, DTS decoder
- 106 cm x 13.1 cm x 7.8 cm
- 6.2 kg
- Product Type
- Enclosure Colour
- Dark titan
Speaker System
- System Components
- Sound bar
- Speaker Type
- Active
- 40 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 4.0, Wi-Fi
- Built-in Decoders
- Audio Formats
- Speakers Included
- 1 x sound bar
- Speaker Details
- Driver Details
- Sound bar: 6 x full-range driver , Sound bar: 3 x tweeter driver
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , SPDIF input (TOS Link)
- Included Accessories
- Remote control, wall mount
- 106 cm
- 13.1 cm
- 7.8 cm
- 6.2 kg
